How-To: Front Plate Holder Removal
Old Jul 10, 2004
Wowak's Avatar
First, go to Autozone and buy some nylon push-in fasteners.
You need two that have a head about 1/2" - 5/8" in diameter; about as big as the head of the rivets that hold the plate holder on.
Get some Duplicolor spray paint to match your Ranger's paint, as well as a can of primer (trust me, you want to use the primer.) Poke two "X" shaped holes in a piece of cardboard, and push the pins through them, but not all the way (so you can paint the sides of the head, as well as the face.) Prime and paint the two fasteners following the directions on the spray can, using many thin coats to avoid runs. Allow 24-48hrs for the paint to dry thoroughly, or else you'll end up with thumb-prints in the paint when you install them.
To remove the plate holder, first remove the front plate if there is one. If you reach behind the bumper you'll be able to feel where those two rivets come through the steel portion of the bumper. Its a tight squeeze, but with a little effort (and probably alot of grease on your hands) you can grab the back of the rivets with grip-lock pliers. This step is important because otherwise the rivets will spin when you try to drill them.
Put a metal-cutting bit in your drill, and SLOWLY drill through the center of the rivet. You want a bit that is 1-2 sizes larger than will fit into the hole in the center of the rivet. Drill until the head of the rivet pops off. Repeat for the 2nd rivet and remove the plate holder.
Now, if the shank of the fasteners you painted are larger than the rivet hole, simply push them in and you are done. In my case they were not, so I found a small nut (it was the nylon-threaded nut that came with the hex-headed license plate bolts I had) to fit the shank, reached in behind the bumper and threaded it on firmly. I used my knuckle to hold the fastener in to avoid pressing a fingerprint into it.
Result: No pesky plate holder that I never wanted in the first place.
New problem: I'm really jonesing for an upper and lower speed grille. 8)
Disclaimer: Do not remove your front plate if your state requires a front license plate. Brian Wowak accepts no responsibility for damage to your property or person caused by attempting this modification.
Old Apr 27, 2006
Wowak's Avatar
One update: use primer. Plain duplicolor WILL chip readily off of nylon.
Old Apr 6, 2017
grunt98444's Avatar
The '09 was much easier, just unbolted the two bolts on the bottom holding the bracket and it was gone, used the bolts to mount the cut down and bent plate to keep it legal.
01RangerEdge
Fabrication & Tool Tech
Jan 9, 2011 02:43 PM
NVRDONE
Jun 30, 2009 03:10 PM
JWall
Jun 16, 2009 07:58 PM
rolsmojave3
Sep 27, 2008 11:02 AM
GregsEdge
Oct 6, 2005 11:02 PM
