auto tranny to manual tranny swap
Old 08-03-2005
Draimen's Avatar
A good friend of mine found me a crashed 2002 xlt ranger with the 5 speed manual....I would love to have manual in my truck....what would it take to straight swap the manual in for the auto? The crashed truck and mine are identical minus the year difference. Plus its only got 20k some miles on it.
Old 08-03-2005
It wouldn't be too hard when working from the right donor truck. Luckily a 2001 and 2002 are nearly identical, as long as they are both 4.0L and both 4x4s. In addition to the transmission, you'd need the clutch, pressure plate, flywheel, brake and clutch pedals and mounts, clutch master cylinder with pushrod and hydraulic lines and the manual transmission PCM. My guess is that the transfer cases are the same as long as they are both the B-W 13-54 shift-on-the-fly electric units (highly likely).
The plastic trim is different on the steering column and there is a manual ignition switch blockout lever to replace the automatic's column shifter interlock. It may involve swapping the columns between the trucks but I doubt it. My guess is that you should be able to swap all the necessary bits from column to column.
The instrument cluster would need to have the gear indicator removed for a clean job. It just gets swapped with the blanking plate from the manual truck's cluster.
You also need the harness down to the transmission - it has different wiring for the manual transmission and I believe it may involve swapping out the entire engine/transmission harness. There are also slight differences under the dash for the clutch pedal position switch wiring.
Do yourself a BIG favor and replace the slave cylinder while it's apart, even though it only has 20K on it. It is a time bomb on any Ranger manual and requires that the transmission be pulled back out to change it.
Old 09-03-2016
I have a 2003 ranger 3.0 auto. trannys gone second one in less than a year i want to swap it over to manual trans . i have a 2000 xlt ranger 3.0 with manual trans will this swap into my 03 ? if so what else do i need for complete swap
Old 01-27-2022
Will a 3.0 bellhousing bolt to a 4.0 transmission? 94 a4ld
Old 01-28-2022
RonD's Avatar
Received 2,820 Likes on 2,586 Posts
No, different bolt pattern
Rangers used 4 engine patterns(not counting the short lived diesels in early 1980s)
2.3l/2.5l Lima
3.0l Vulcan
2.8l/2.9l/4.0l Cologne
2.3l Duratec
None of the 4 are interchangeable
There are also 2WD and 4x4 versions of the first 3 which are also not interchangeable, a 2WD trans won't work in a 4x4 and visa versa
2.3l Duratec never had a 4WD option transmission, they only came in 2WD
With an automatic you CAN disassemble the transmission and swap bell housings, if they are similar models, i.e. both A4LD
But.............if disassembling its just better to rebuild what you have unless the bell housing or main case is broken
bail315
06-01-2011 05:53 PM
ericm98
03-30-2009 08:05 PM
crawly1025
09-11-2008 01:01 PM
RaNgErbRo
09-02-2008 06:48 PM
markw_06
11-06-2006 01:31 AM
Quick Reply: auto tranny to manual tranny swap
