OLD - Suspension, Tires, & Wheels Ford Ranger suspension parts, tires, and wheels, i.e. suspension lift kits, body lifts, wheels, and tires.
For Sale: New! Full Coilover Conversion - Fox, Hypercoil, Brackets, 1" BL - WA
Old Dec 23, 2012
1 Bored Clerk's Avatar
After much debate, I am selling my coilover conversion. I bought this last spring and just never installed it. Not going to keep the Ranger for too much longer so there's no point in installing it now. It's all brand new...never been installed. Heck, it's hardly been out of the box! **Will not fit a Superlift truck**
What's included:
Coilover Brackets - From the Forum Member here that builds them. Powdercoated black with stainless steel hardware.
Fox Coilovers Valved for 800lb springs (for the weight of aftermarket bumpers, armor, and a winch) I specified that my truck was a daily driver and slow trail runner. Not valved for high speed desert thrashing. Springs and revalves are relatively cheap if you want it changed.
1 set of Hypercoil 800lb springs
1 set of King 800lb springs (these were the springs I got first but the powdercoat was so chipped up that the company sent me the hypercoils as a replacement)
Wrench for adjusting coilovers
12 1" Body Lift Blocks from Summit Racing. PRA-BB01
All of this is brand new, never installed.
$700 shipped anywhere in the lower 48 states. That's a big discount over retail. I believe the coilovers were over $700 all by themselves.
PM's are fine, but a text message or phone call will get a quicker response. 541-399-2567.
Patrick
Attached Thumbnails New! Full Coilover Conversion - Fox, Hypercoil, Brackets, 1" BL - WA-cimg1959.jpg
Old Dec 23, 2012
FULLSCALE's Avatar
That's a good deal... if I still had my Ranger these would be already sold!
Old Dec 23, 2012
PAShooter's Avatar
How much for only the coilover setup? No BL blocks?
Old Dec 23, 2012
Same price. The BL spacers are worth about $12 retail so you get them whether or not you want 'em!
Old Dec 23, 2012
Taylor's Avatar
Ive been dubbed....an old volk
WOW.
This is a great deal!
Old Dec 23, 2012
PAShooter's Avatar
Would these be fine even with a bumper and a v8? or would it sag. Im very interested in these if they would work with my truck
Old Dec 23, 2012
I would guess you would still have room to add more weight. Most folks with coilovers on otherwise stock rangers seem to feel that 550-650lb coils are 'about right'. So, 800lb coils ought to have more than enough in them to support the weight of your truck. I can't, of course, guarantee that as I don't have any personal experience with it. Even if you decided to go slightly heavier (or lighter) on the springs, the valving would at least be close...maybe close enough to not bother to change. And, springs aren't terribly expensive (Less than $100 if I remember correctly)
Downsouth motorsports recommended this heavy of a spring for my 'planned mods' of bumper, winch, full skid plates, and rock rails. I would say that all of that would be more than the added heft of just the V8 and the front bumper. Most people don't fully realize how heavy armor actually is!
I wish I had better info for you other than 'close enough' or 'probably good'.
Old Dec 23, 2012
Red_Ak_Ranger's Avatar
Someone buy this **** now. It's a great deal. If his truck was superlifted I'd already be giving him all my cash.
Attached Thumbnails New! Full Coilover Conversion - Fox, Hypercoil, Brackets, 1" BL - WA-f_bb6363486a.jpg
Old Dec 24, 2012
DSFD506's Avatar
Judging by AK's post i'm guessing these are for stock setup ?
Old Dec 24, 2012
Correct. However, I think you can buy the extended lower coilover mounts for Superlifted trucks. Fox makes both. If you're handy (and careful) you can swap them out yourself. Or, you can have a shop do it for you. I can't remember if the superlifted trucks could run a longer travel shock...
EDIT** Not suitable for Superlift Trucks...see post below by Logan03CO.
Old Dec 24, 2012
logan03CO's Avatar
The coilover's you have pictured already have the extended lower eyelet installed on them. They are needed to clear the CV setup in both stock & superlifted setup's.
If your Superlifted you need to run a longer travel coilover (6.5" versus 5") & spring (12" versus 10") combination.
Old Dec 24, 2012
Originally Posted by logan03CO
Your coilover's already have the extended lower eyelet installed on them. They are needed to clear the CV setup.
Superlifted trucks would run a longer travel coilover (6.5" versus 5") & spring setup.
I stand corrected. Thanks for setting it straight for folks. I couldn't remember which way it went...it's been a while!
So, no, these will not work on a Superlift Truck.
Old Dec 24, 2012
logan03CO's Avatar
x2
Can't believe this isn't gone already!
Old Dec 24, 2012
x2
It might have been cruel of me to post this just before Christmas.
Old Dec 25, 2012
04_xlt_4.0_4x4's Avatar
never thought about going coilovers so not knowledgeable at all on them. so how would this help a stock 4x4 trk and what would it do as har ar ride height for it? ALSO.... what would be the install process?
Old Dec 25, 2012
What a lot of noob questions for a 1000 post non noob.
1. coilovers are better ride than torsion bars. Should be pretty obvious..
2. Ride height would have the potential to be a bit higher (your torsion bars are prolly a bit worn out and the included springs are pretty high strength so you would have some lift)
3. Why not search? There's a huge "coilover conversion" thread that is always posted in so you can't have missed it. Install is easy with a slight bit of welding. If you haven't removed a t-bar..it's pretty easy except for a few annoying stuck together joints and bolts.
Old Dec 25, 2012
haha thanks!!! i have a 1000 posts but i have never looked at or thought about coilovers. plus loook at it as a free bump lol
Old Dec 25, 2012
morris's Avatar
Lets see if someone chimes in, I'd need 550 or 600 springs. I'd have to order 2.5" id and in a 10" length?
Old Dec 25, 2012
Why is this morris
Old Dec 25, 2012
morris's Avatar
Because the 800lb springs he has are "too rough" for a stock ranger. He had them ordered cus he wanted to add a couple hundred pounds of front bumper/winch, whatever else....
"Fox Coilovers Valved for 800lb springs (for the weight of aftermarket bumpers, armor, and a winch) I specified that my truck was a daily driver and slow trail runner. Not valved for high speed desert thrashing. Springs and revalves are relatively cheap if you want it changed."
Old Dec 25, 2012
atrocity's Avatar
2.5" in 10" is what you want to go with. On the coil over thread 700 or 750lb is recommended for a stock truck, I can't remember which though.
Old Dec 25, 2012
morris's Avatar
Thanks.
Old Dec 25, 2012
logan03CO's Avatar
My guy recommended a 750 lb spring - but others seem to like the 600's.
I know the original RCD coilover suspension kit came with 600's (all of this is based off of that original kit). A couple people said they would 'sag' a little over time. Hence the 700's or 750's.
You are correct on the inside diameter & length for a stock setup.
The springs should only run about $60 a pop. Pretty cheap to change things out if you don't like how they ride.
Old Dec 25, 2012
morris's Avatar
Yea, I figured that part out.
What if I wasn't happy with the valving. Would I be able to re-valve on my own or would I have to ship them out to a shop?
Old Dec 25, 2012
logan03CO's Avatar
I'm not sure this thread is the right place for this conversation (sort of cluttering up his for sale thread)....but:
Fox shocks can be revalved on your own....but it's not something you want to dive into without knowing exactly what your doing. They use a series of shims and depending on the pack that is used, you can change the compressions & rebound damping.
Good Resource for coilover knowledge:
Part #1 (Basics - Theory & Calc's): http://www.pirate4x4.com/tech/billav...lovers/Part_1/
Part #2 (Hands-On - Rebuild, Spring Change etc): http://www.pirate4x4.com/tech/billav...lovers/Part_2/
