Sponsored by: DashLynx
T-Bar crank question
Old 08-30-2005
Ranger1's Avatar
I know there are alot of post about cranking the T-bars but here is another one. I searached and searched and did not want to post this but anyway could find the answer
I think the general idea is its bad to crank the T-bars all the way. Right ? How much is ok ?
Also is there any other way to get another inch or 2 out of the front of a 4x4 ?
Old 08-30-2005
Splitfire's Avatar
Only way to lift it without spending a lot is by the t-bars. Just crank them as desired and make sure that both sides are evenly cranked (jack up the truck and do it, then keep measuring both sides from the top/middle of the tire to the fender on the one side, and the same on the other until you can get it at the "height" you want while still keeping them level.) Also, be sure to use the right socket, as those things are easy to strip. Be sure to get an alignment afterwards as well, the crank will throw your camber off.
The only bad thing about cranking them all the way is that your upper ball-joints will start to bind (bad), but many people have done that and have been fine for a long time until the ball-joints needed replaced. Just recognize you're taking that risk, and it's an expensive one as Ford sells the arm/ball-joint assembly as one that is, I believe, $113.67 or something close to that (each). Let us know how it goes and post pics.
Old 08-30-2005
RacerOver's Avatar
I'm thinking about doing this as well. I just want to level out the truck as the rear sits an inch or two higher. Will this hurt the ball-joints as well?
Old 08-30-2005
Splitfire's Avatar
It can cause them to bind, which will make their useful life a shorter one. It won't completely level the truck out, but you should be within an inch of level.
Old 08-30-2005
RacerOver's Avatar
Good info in here. I'm gonna do this. I only have 17000 miles on the 04... so, it shouldn't be that big of a deal.
Jason
Old 08-30-2005
Trevelyn1015's Avatar
Still El Presidente...
i have had cranked tbars since 4000 miles...
i now have around 50ish...
never had any problems related to them...
Old 08-31-2005
Ranger1's Avatar
How far did you crank them ?
Is there anyone on here that cranked them all the way in ?
Old 08-31-2005
Morph's Avatar
I did 6 Complete turns about 4K Ago with no major problems thus far.
Old 08-31-2005
MonsterGuy's Avatar
so if i just bring my truck level is that bad or not good cause i need 1 1/2" on drivers side and 1" on passengers side
Old 08-31-2005
Splitfire's Avatar
I cranked them all the way, but I also don't have upper balljoints to worry about anymore.
Old 08-31-2005
Ranger1's Avatar
why don't you have upper balljoints ?
Old 08-31-2005
034x4's Avatar
Not sure what company but i think he has one of the "monoball" designs so there is no upper balljoint.
Old 08-31-2005
the kit that weldtech makes for like 900 gets rid of the ball joint i believe.
http://www.weldtecdesigns.com/FRNW4x4.htm
Old 08-31-2005
034x4's Avatar
Ah they call it a uniball not monoball lol i was close.
Old 08-31-2005
Ranger1's Avatar
Its basiclly a 3 inch lift kit for $900, and it replaces the front upper ball joints. Can you crank the T-bars up with that also because I am thinking 3 inches is about equal to the T-bars cranked all the way up.
Also will those work with a super lift ?
Old 08-31-2005
Splitfire's Avatar
There are uniballs and monoballs, monoballs are what shops install for pivot points for your lower arms and steering mainly (heimes on uppers most of the time) and uniballs are for pivots where your spindle is most of the time. They are made by tons of different companies.
I have Camburg's 6.0 kit, so my upper ball-joint and arm was replaced by a new arm and 1" uniball on either side.
The arms will work with a superlift, but the superlift will get in the way of any added benefits to your travel numbers, making it more expensive than it's worth.
Old 08-31-2005
PotterFX4's Avatar
so this is a 3" lift for $900 (+/-). What are the benefits of getting this vs a superlift other than the extra 1"?
Talk to me like a 4 yr old, I dont know that much about what all is involved with the weldtech kit. Thanks.
Old 08-31-2005
by the way i understand it you get the lift that 3 inches from cranking the torsion bars, the kit just makes more travel and better with the uniball instead of the balljoint, o me i would think this would be a better kit than superlift, as it adds travel and the superlift doesnt.
trent could tell you he knows more than me.
btw trent i havnt seen any updated pics of your truck in a while?
Old 08-31-2005
Ranger1's Avatar
oh so you still only get 3" of lift either way and it still comes from the T-bars being cranked. Only benifit is better travel.
Old 08-31-2005
ya 3 inches from stock no t-bar crank, this alows you to unitilize every bit of cranking your t-bars
Old 08-31-2005
TippnOver's Avatar
mine are a hair away from fully cranked i think....i cant remember
no problems thus far with offroading and crazy doughnuts.....
Old 08-31-2005
Splitfire's Avatar
I'll post more up when I get back from shopping for school . . . SICK!
It's a secret, I'll post pics this weekend, .
Old 08-31-2005
well i cant wait that long...
Old 08-31-2005
Splitfire's Avatar
Haha, you'll have to, .
Quick Reply: T-Bar crank question
