Winch setup and carrier
Ok Guys, need some input. im thinkin about getting a winch. My only deal, is i dont like the way the carriers look.
Do you folks know where i can get a decent carrier that dosnt look just all like junk?
i cant find one like brian (blktremor02) had, cause i liked the way it looked.
Many Off-road shops will build one for you, or look up local metal fab shops. Im sure they would too.
But im thinking about going with the front hidden hitch with winch attachment. Its the best idea really. You can remove it and store it in the tool box. And when needed, it can be used in front, or out back. I just have to get a front hitch, and a rear hitch first.
Besides Tom, if you get a front bar, you loose your pretty lil WAAG bar.
on
Get a front hitch, and you can get hitch-winch mounts. All you do is put it in the receiver and plug it in. Also good if you need to pull yourself out backwards.
Keep it in the back of the cab or in a lock-box in the bed until you need it, no excessive weight on the front end all the time.
i've been debating that idea too for a while.
I'm thinking 2-2.5in square tubing, welded in between the frame rails and the front support beam, i saw it on here somewhere that way. My only concern is, how hard is it going to be to put the pin into place on the hitch with it back behind the bumper.
How about this one blkout?
Ranch Hand Bumpers
I'm not sure if they make one for a Ranger but it looks pretty sweet.
Ranch Hand Bumpers
Originally Posted by BlkTremor02
If they haven't changed the front end mounting points from 03-04, then you can have what I had on my truck..Mounting points meaning where the tow hooks are and the 2 holes close to the top of the front bumper..If you have them you are set to go man!
sweet, do you have some picture of your old winch setup?
i wanna gander some more at it
http://www.cardomain.com/ride/359530/3
Just scroll down towards the bottom and you'll see about 9 pictures for ya!
