How-to: Remove seat belt bar on explorer seats
Old 04-03-2006
birdie2000's Avatar
Okay, I was speaking with a member some time ago about making brackets for the seat belt rail on explorer bucket seats. This rail bolts to the hump on the explorer, but is rather useless in our trucks. When I was test fitting the seats after making the inside rail holes of each seat big enough to be able to use the ranger bolts, I found that this bar hendered the movement of the seat. So I decided to get rid of it and here is what I did:
Tools needed:
Dremel tool with cut off wheels and a ginding stone
Assorted hand tools
Drill with 1/2 inch drill bit
Here is the bar that I was talking about:
I removed it and there were these 2 brackets sticking out:
So I removed them...I dont think you have to remove them, but I did.
Now there is nowhere to attach the seat belt, but there is this hole:
I peeled back the cloth so I could really see... again maybe needed maybe not. The hole is a little to small. I used the 1/2 drill bit just to make the hole a little bigger, then I used the dremel tool with a grinding stone to get the last little bit. I could have used a bigger bit, but i did not want to make the hole too big.
Okay back to the bar. The bolt that goes to the floor in the explorer seemed like a good choice to attach the seat belt to the seat. It has a space near the top before the threads start. This will allow the seat belt to turn.
Here it is in the seat belt hole:
To attach the the seat belt, I bought some lock nuts (I forgot to ask the size) and just installed them (its pretty easy )
And last but not least, put the new seats in your truck and you dont have to worry about the dumb seat belt bar!
Well thats it. Hopefully ya'll find this usefull!
Old 04-03-2006
Dangerranger01's Avatar
Nice job dude. Do the seats plug into that wire that goes onto the stocker seat? What does it do anyway? Again, sweet mod.
Old 04-03-2006
birdie2000's Avatar
the yellow plug is for the seat belt pretensioner which we do not have. the driver seat has a gray plug that is for the power adjustment.
Old 04-03-2006
Well, on mine on my brothers rangers we got wires under both ours (mine-XL, his XLT both non power) so the wire does what? Seat belt pretensioner which isn't on the explorer seat? I don't know, thanks anyway mister.
Old 04-03-2006
birdie2000's Avatar
the wire that is attached to your seat is for the seat belt light.
found this that explains what a seat belt pretensioner is
http://www.tierone.com/seatbeltpretexcerpt.html
Old 04-03-2006
Oh man, thank you sooooo much. For the longest time I had thought that you couldn't put in explorer seats without dealing with that thing. So, I guess it just needs to bolt down into your floor, and deal with the seat belt light. Thanks again, dude.
Old 04-03-2006
birdie2000's Avatar
since the light is for the driver side...i am going to take the seat belt off of the stock seat( the wire is attached) and put it on the explorer seat the same way that i did this one. that way the connectors match up.
Old 07-05-2006
another thing i did was just swap my seatbelt bar off my 60/40 seats onto the explorer seats.....they bolted right up and attached to the floor great.....
took forever for me to try this but i did it last weekend...finally
bmfmancini
07-01-2023 10:47 AM
x182dan
01-25-2014 12:33 AM
boyd_835
01-15-2014 10:34 PM
drppdyllwrngr
30
03-16-2010 07:38 PM
MyYellowRanger
06-15-2004 01:51 PM
Quick Reply: How-to: Remove seat belt bar on explorer seats
