Ranger Products, Company, & Member Reviews Like a Ford Ranger product? Perhaps a product was not up to par? Did a member impress you? This is the sub-forum for you.
Screamin' Demon Coil Pack Review
Old 03-31-2007
I got one of these to try from Wayne because I've had an impulse noise problem from my spark system that has been troubling my radios. I asked for one to experiment with, but I think I'm buying it after all.
Here's why:
1. Build Quality: it's excellent. Davis Unified Ignition makes some great stuff and this is no exception. He picked the right folks to make it. Bolts in with no stress -- perfect alignment. Wires snap in right and tight. Boots seal as they should to it.
2. Noise level: it's reduced, but not gone. Also, the "tone" of the noise is thinner, and more tolerable. Although it didn't eliminate it, it did improve the situation. Impulse noise is hard to measure as a "level" so I can't give "s-units" or anything, but it's reduced in volume and is more of a "tick" now and less like a "pop" -- if that makes any sense, lol.
3. Engine: my idle is smoother than it's been in ages. I have a 3.0 with the MAF mod and they do idle rough -- but this seems to improve it. That in itself is impressive.
4. Gas mileage: I seem to have a bit more gas mileage, about .5 to 1 mpg. I've been getting very repeatable numbers since I reflashed and run 93 octane, so this may be significant. It could also be nothing. I can't really give a very good report on this. You'll have to make your own evaluation.
5. Performance: well, I didn't expect it to do anything, but it FEELS like it actually did. One reason may be the Bosch Platinum Plus 4's I run. They have very big gaps and I think this coil drives them a lot better than the stock coil did. I have no objective measurements to offer here either.
But, taken as a whole, this coil IS an improvement over my stock coil. Whether that is because my old coil had an issue or not I can't tell you -- I don't have equipment to really measure a high voltage spark coils performance.
So, for the price it is, I don't think it's really much of a risk. It's a good piece manufactured by a solid company and sold by a good vendor.
My .02
Old 03-31-2007
i love my Screamin' Demon.....if i had to do over again, i would still buy it....worth the money....
like you said, the idle is a lot better and you do get a bit better milage....
Old 04-01-2007
Mr. Griggs, thanks for the review. Ill keep it in mind.
Old 04-01-2007
red_fx2's Avatar
id like to get one of these when i get the $$.. good review john..
Old 04-01-2007
how much are they?
Old 04-01-2007
pastfinder's Avatar
I'm thinking of installing one of these as it is cheaper and easier to do than installing new rockers. I also have over 60,000, closing in on 70,000 with the stock plugs and wires, so I need a reason to change them out as well. This should do the trick.
Old 04-01-2007
Originally Posted by gatorblue92
how much are they?
$99 for the 3.0......
$89 for the 4.0......
Old 04-01-2007
About $100. I think you can find them on http://www.stuffforyourranger.com if I have the URL right. I was in a dialogue with Wayne about testing one and didn't order through the site so I'm not sure.
Old 04-01-2007
Old 04-03-2007
fletch12518's Avatar
I'll be using that link for sure! I take it only took about 5 min to put in huh? looks way too easy
Old 04-03-2007
I have been toying with the notion of putting one in my truck and the old lady's taurus, I think you just sold me John. I was for sure gona do the taurus, but now I think my truck needs one!
Old 04-03-2007
why didn't my review get this much response
........maybe they only believe the geniuses!
Old 04-03-2007
i believed you dork
Old 04-03-2007
I think because I originally expressed doubts that it would make any difference in view of the "hot" nature of the factory system. So my "conversion" is somewhat more dramatic -- the "hostile witness", lol.
My main reason for trying it was to see if it helped my noise problem -- any performance benefit was gravy.
Old 04-03-2007
Old 04-08-2007
RangerEdgeO2's Avatar
How many volts is this coil putting out?
Any idea how much the stock one is putting out?
Old 04-08-2007
I have no idea, and no idea, lol. I haven't the equipment to measure that.
You need a calibrated scope with a high voltage probe to do it right since it's a decaying AC wave form. Ideally, you would check not just the voltage but the decay time as well.
A simple voltmeter won't tell you anything but one peak, or an average over a longer time than the spark lasts and isn't very useful.
I have a scope, but no compatible high voltage probe system for it.
Old 03-23-2008
old thread i know but i finally got one of these and my truck idles smoother than any 3.0 i have ever seen... in a ranger or a taurus... the performance is probably a little better than stock but way better than my bad coil was... well worth the $100.00 purchase price from underdog
Old 03-23-2008
i_luv_strats's Avatar
I love mine, works like a charm!
Old 03-23-2008
I need to get one.
Old 03-24-2008
Takeda's Avatar
Level I Supporter
There have been many articles posted about how useless the aftermarket ignitions are (including coil packs). Not only that, but these aftermarket companies don't do any reliability testing at all, compared to Ford's requirements from their electronic component suppliers! The voltage produced by the coil will be clamped at the point the spark plug fires,
so there will be no difference in the OEM coil pack, and the Screamin Demon!
With the plug wires, and plugs in good shape, and there is no misfire, there will be no performance improvement in aftermarket ignitions!!
Old 03-24-2008
maybe so but it was about $30 cheaper than one from autozone so it was worth it
Old 03-24-2008
The difference in my case relates to the wide-gap Bosch Platinum +4 plugs. These plugs have gotten a bad rep in some circles and I think part of that is that many ignition systems don't fire them well enough. This may account for my noticing a difference.
But you're correct about the Ford DIS: it's gotten the reputation of being one of the best factory ignition systems out there.
Old 03-24-2008
Takeda's Avatar
Level I Supporter
The OEM EDIS coilpack has more than enough voltage to fire the gap on Bosch plugs! The problem with Bosch plugs is they run too hot in Ford applications, and they don't handle the EDIS opposite spark polarity well
at all!! Stay with Motorcraft double or fine wire platinum plugs and there
will not be a misfire problem.
The do, however, run well in my gas Mercedes!
Old 03-24-2008
Bob, I remember you from years ago on other forums, and you've always been a "shill" for FoMoCo products. I'm not impressed -- either then or now -- by your total partisanship on these things.
I'm surprised you even show up in any forums on mods -- you're predictable and we can always rely on you to say "you can't do it better than Ford already has". You're ridiculous, inaccurate half the time with your arguments, and get so emotional in simple fact based stuff that you destroy your own credibility.
For such a old timer at this, you are shocking in your inability to learn.
Nuff' said. Another Bob Ayer's Ford rant dealt with -- no need to take it further.
Quick Reply: Screamin' Demon Coil Pack Review
