E-Fan vs truck temp?
Ok living in arizona I'm really worried about getting an Efan. Its been 114 a few days (I think) already and Im real worried that if I get an Efan that it wont cool as good as my stock fan. I just want to hear how your guys temps did, both engine temp and a/c temp after install?
Not to down the efan, but my truck has not been the only truck it failed on.
I had the fan on for a while. When city driving, tranny was at 180* and ac was starting to get warmer than usual. When offroading, my tranny would reach 210 and the engine would actually run hot enough for the stock temp gauge to start going up and eventually overheat itself.
After I threw on the stock fan, it is 97* out today 100 percent humidity, I just drove about 25 miles city and my tranny was 165, A/C cold as can be, no problems. when I go offroading (almost never anymore, but when I first did the efan) I was running 180 at the max tranny temp. Engine never even came close to heating up.
Ask Kevoo (kevin) what he thinks about the efan, his took a crap on him down in ft lauderdale, about 30 mins from our houses. The controller failed, then his fan failed, so we put his stock fan back on. Works like a charm now, a/c is colder to boot. But when he would go offroading we would have to stop, let the engine cool down, and then go again, PITA
I highly reccomend against an e-fan, I want the least electrical things on my truck to go wrong. Plus your towing will be affected, and your tranny temp goes up, a/c isn't as cold. Just 2 trucks this happened to. I hated my Efan, not saying it's a bad product, just not for me.
I took my efan out to Death Valley and 105 degree heat while climbing hills and offroading and I had no issues with overheating or AC troubles. Granted, I do think the tranny runs a little warmer, but without a gauge I am for naught to give a definitive answer. I like it if for nothing else but the engine is quieter.
i cant seem to keep my truck cool with the efan.
I was forced to buy a replacement while wheeling at the dunes because the Efan died. The one i have now does not have enough CFM for running the A/C and running the truck through a city. It just continues to get hotter and hotter but i have never tested it to see if it would over heat.
As for the tranny i had to add an additional cooler to maintain cooler tranny temps.
great... I read this after I just installed a efan! Now you guys have me worried!!!! I'm about to drive 2300 miles to Ohio and I don't want to get stranded. crap.
I may just bypass the fan controller and wire it to come on all the time when the truck is on.
My lil 4 banger seemed to run cooler today, and I can't say if the a/c was affected or not?
my efan has worked flawlessly.....my a/c is cooler than it was with the stock fan, my engine stays about the same temp, and my tranny stays about the same temp......when driving anything over 50 mph, you don't even need a fan......
the proper efan will pull more CFM than the stock mechanical fan.....i would however recommend mounting the efan in the stock shroud that way it pulls the air through the entire radiator......<< i think that is were some of you guys are running into trouble from...
Originally Posted by Takeda
Not true!!!!!
the Jusnes Modified fan pulls around 2250 CFM, that is more than the stock 2000 CFM fan.....hmmm the math were i come from shows that it is more....
there is even fans on the market that pulls up to and over 3000 CFM.....
read what i said again:
wanna bet
it is all about sizing properly....
then show me what it is......prove me wrong....if all you can do is say "you are wrong" then who is to believe you.....
that 2000 CFM figure came straight from Ford.....
Ok, lets see if from some place other than an e-fan manufacturer!!!!!
I guess you believe all the claims from Tornadoes, Splitfire plugs, and K&N filters too!!!!
you do not need the stock shroud, the efans have shrouds already.
as for the efan not needed on the highway, ride with me on a hot day i can show you the differences of running and not running an efan on the highway, shows right on my gauge.
I like the efan but buy the best your money can buy.
