Underdrive pulleys
Old 06-27-2007
txboy11's Avatar
Underdrive pulleys
I want to buy one of these kits... a couple questions
Which one Is the best?
What do you guys have?
How much?
Ease of Installation? Do it yourself??
Old 06-27-2007
vindex1963's Avatar
Old 06-27-2007
UNCCRang49's Avatar
or you could buy from....http://www.jusnesmodified.com/store/...th=155_183_267
I highly recommend them! and if ya wanted a little more you could get powerpack #2 which is the pulley, gatorback belt, and e-fan for $250.
Old 07-04-2007
Z06's Avatar
Z06
Z06 is offline
I just placed an order with Underdog-Performance for an underdrive pulley and Gatorback belt. Main reason for his support and answering any question that is asked. Thanks, that is appreciated and the way to get business! The check is in the mail, really! It will be from Netbank and has the order # and my name on the memo section.
Bob Hardt
Old 07-05-2007
underdog-performance.com I have bought from them before and would do it again
or
http://www.jusnesmodified.com/ they are on the forums and good people, would deal with them anytime also
Old 07-05-2007
graniteguy's Avatar
ryan, here is a how to I made up for the install. I can do it in an hour. Most guys do it in 1-3 hours. If you can get to Austin I would install it for you:
http://stuffforyourranger.com/How_To...nderdrive.html
Old 07-06-2007
Z06's Avatar
Z06
Z06 is offline
Wayne,
Just ordered the Rogue X II and tunes. Thanks, good deal. So I will have the crank pulley, gatorback belt, and Rogue coming as soon as you receive my 2 checks. Mailed the last one thru my bank tonight.
Bob
Old 07-09-2007
Z06's Avatar
Z06
Z06 is offline
Wayne,
Are you around? I sent you a pm about my goof with the VIN# and just wanted to make sure you have received my correction and now have the right one.
Thanks, Bob
Old 07-09-2007
graniteguy's Avatar
Yes. I got the info.
Old 07-09-2007
Z06's Avatar
Z06
Z06 is offline
Icon7
Thanks, looking forward to receiving my stuff and installing all of it.
Old 07-20-2007
Z06's Avatar
Z06
Z06 is offline
The tensioner pulley, where is it located and how do you adjust it? Only question before tackling this install. Thanks,
Old 07-20-2007
vindex1963's Avatar
When you are standing in front of your truck it's the small pulley just to the right of the pulley that drives your fan and water pump. You DON"T want to remove the pulley just use the 15mm wrench and pull or push and you will see it move to loosen your belt.
Hope that helps.
Old 07-20-2007
graniteguy's Avatar
Adding to toms post, the tensioner pivots. It is not removed.
Old 07-21-2007
Z06's Avatar
Z06
Z06 is offline
Hope that helps.
Thanks, should be able to figure it out now. I appreciate the help found here. On another subject, I see you have a different thermostat installed. What does this do? I don't have an e-fan and planning to see what the tune and pulley does before going further.
Bob
Old 07-21-2007
pastfinder's Avatar
Wayne's and Bob's underdrive pullies are identical units from the same manufacturer, for what it's worth.
Old 07-21-2007
Z06's Avatar
Z06
Z06 is offline
I'm the Bob above and I bought a Wayne pulley!
Bob
Old 07-21-2007
vindex1963's Avatar
I put the thermostat in because here in Phoenix it gets 110+ and on weekends I go up into the mountains for hiking or offroading. The temp gage didn't seem to go up but the under hood temperature seemed high. I could open the hood and get BLASTED by the heat. Now it's not like that. I've also read it helps in pinging and I am running a 91 tune.
Old 07-21-2007
Z06's Avatar
Z06
Z06 is offline
What's the stock one?
Old 07-21-2007
vindex1963's Avatar
197* I also added Water Wetter
Old 07-21-2007
Z06's Avatar
Z06
Z06 is offline
Is the 91 tune high test in your area? I have ordered the mpg 87, the perf 87, and the perf 93. Will probably just run the 87 though to save money on gas. Going for mpg with this truck. I got a little something else to drive when I need to satisfy my go fast urge!
Did you notice a mpg improvement after doing the tune?
Old 07-21-2007
vindex1963's Avatar
I'm still kind of getting my foot into it. There is a very noticeable difference with the 91 tune. Yes 91 is the highest test we have.
I filled up today before going to the mountains and got 19.889 mpg. That's with testing my 91 tune more than I should have. I was averaging 23 so if it stays the same I'll be happy.
Old 07-21-2007
vindex1963's Avatar
So did you get the pulley installed?
Old 07-21-2007
Z06's Avatar
Z06
Z06 is offline
No, my grandson is visiting. We are taking him to the circus tomorrow, then he goes to the other grandparents. Supposed to do the pulley tomorrow afternoon. My tuner is on the way from Wayne, should get it middle of next week. Its actually my wife's truck, but I like to tinker and mod it up a little.
Old 07-22-2007
Z06's Avatar
Z06
Z06 is offline
Underdrive pulley and belt installed today. We followed Wayne's directions and had no problems! Drove the truck, feels sop more responsive and hoping for better mpg. Thanks Wayne, now just waiting on my Rogue tune and device to arrive this week and hook it up!
Underdog is great to deal with, don't hesitate to give Wayne a call or e-mail, he answers your questions and its appreciated!
Bob
Old 07-22-2007
vindex1963's Avatar
Bob
You will notice Wayne with the pulley and Fred with the tune will answer your questions no matter how goofy they seem to be. I'm dropping my hard earned money so I do expect my questions answered and quite a few businesses out there don't seem to realize that.
Quick Reply: Underdrive pulleys
