How do i Change the lights in my dash board?
Old 01-11-2008
FordFever's Avatar
Is it a major Project or is it some what simple? My truck is a 2002 Ford Ranger xlt. The lights in the dash board by the RPM meter is burnt out.
Old 01-11-2008
FordFever's Avatar
Thanks.
Old 01-11-2008
If you want a step by step how-to w/pics, take a look at this. While you have it apart, it's a good idea to replace all 6 #194 illumunation bulbs. They tend to fail in the same general time frame.
Old 01-11-2008
RentonRanger's Avatar
It looks as if the bulbs can be replaced without tearing the entire cluster apart. It looks like they can be accessed from the back of the cluster. Please correct me if I'm wrong, but aren't the bulb holders a twist/lock similar to say taillight bulbs?
Old 01-11-2008
FordFever's Avatar
Thanks that pic step by step guide is nice.
Old 01-11-2008
Toreador4x4's Avatar
yes john, they twist and lock in a plastic socket
Old 01-11-2008
Fenech627's Avatar
Dont want to get off topic but mine is like that too. I have a 99 ford ranger and my far left dash object wont completly light up. (gas meter)....
Also on my steering wheel at night on the left side my on/off switch for cruise control does not light up, only the right side does.
Same problem/Blown Fuse/ Any suggestions???????
Old 01-11-2008
FordFever's Avatar
i am guessing your dash has a broken bulb like mine. Just try to replace the bulbs in the dash. I am going to try it tommorow. As for the steering wheel thing, i have no idea.
Old 01-12-2008
John...I can't see my self reaching wayyyyy up there and trying to get the bulbs out. Plus...there's not much clearence at all to get a hand up there with the cluster installed. OR....Now that i re-read what you typed....you don't need to tear the whole cluster apart.....just get the cluster out, flip it around so your looking at the rear, twist the holder out, pull out the 194 bulb, replace the 194 bulb with a new one, twist and lock the bulb. done. There are 6 194 bulbs that illuminate. I highly suggest replacing all of them. There's 6 total dash illumination bulbs.
Replace illumination bulbs on the gauges. That should beyour problem.
About the cruise control......pull the positive and neg cables off your battery. Pop the two side covers off the steering wheel to expose the airbag mounting bolts....pull those out with a 8mm socket...carefully full off the airbag and unclip the wiring. Then take a phillips and take off the cruise "pod". It's two halfs, so you'll have to pull the front and back apart. There'll be a "circuit board" (at least i think that's the right defination), and check it out.
If you want....PM me about your cruise pods...as i'm taking mine apart again here in the next couple days.
EmilyRabon
11-12-2014 06:37 AM
jeremyled
04-03-2008 03:45 PM
bdc217
07-02-2007 08:26 PM
FMD
03-10-2007 10:39 AM
kevman41635
07-04-2006 10:03 PM
Quick Reply: How do i Change the lights in my dash board?
