CB Molded Into Expo Console Project
Old 02-23-2008
I know this isn't as big and fancy as some of yalls projects, but I was asked to take pictures as I went so here they are.
I got the idea to mold my CB into the spot where my ac controls are form this picture...
455980_70_full.jpg?t=1203827350
but after thinking about it I decided I'd put it in my Expo console instead.
DSC_0002-6.jpg?t=1203827514
DSC_0003-6.jpg?t=1203827539
I started tonight by doing a little measuring and then some cutting with the Dremel tool.
DSC_0004-3.jpg?t=1203827560
DSC_0005-5.jpg?t=1203827578
I then needed to some how keep the CB in the hole so I cut some 2x2 down at an angle mounted it to the bottom of the CB...
DSC_0007-2.jpg?t=1203827596
DSC_0008-3.jpg?t=1203827675
Then ran a screw through each side of it to keep it where I wanted it:
DSC_0009-3.jpg?t=1203827693
DSC_0011-5.jpg?t=1203827784
Then after it was set in place I started the Bondo:
First coat:
DSC_0012-4.jpg?t=1203827873
Sanded and second coat:
DSC_0015-3.jpg?t=1203827900
I went with Bondo instead of fiberglass, because it's a lot easier to get around here. This is my first time ever using it too. I know it doesn't look pretty yet, but give it a few days and it'll look good. That's it for tonight.
-Mike
Old 02-23-2008
Sandy McSanderson Almighty! Keep us updated there, TRig.
Old 02-24-2008
Biz's Avatar
Biz
Biz is offline
pretty cool,i was suppose to do this aswell but im to lazy..looks like a bit of time and work..cant wait to see it done
Old 02-24-2008
ChrisR1S's Avatar
Here's a curious question: how easily will it be to remove the cb and tape from the bondo? (btw, ive never worked w/ bondo so i dont know and i know you said you havent..) What are your plans for the speaker? lengthen the wires?
Old 02-24-2008
sweet.....keep pictures posted!
Old 02-24-2008
SVT01RANGER's Avatar
looks good mike, i'm gonna keep my eye on this one, i'm thinking depending on how the bondo works out, i may use it when i shave my grille emblem
Old 02-24-2008
I have no idea how easy it'll be to remove the Bondo & tape. I am guessing it won't be much fun. I think I'll end up using a dremel tool to get it off aroud the base of the CB. As for the speaker, i will be getting a small external speaker and mount it somewhere.
last time I was at Radio Shack the had a small 1"x1" that I am wanting to get, i hope they still have it.
As of now I have sanded the second coat of primer and applied the Bondo Putty. I hope to sad it and may be get a coat of primer on it today, but Sunday's are always really busy for me.
Old 02-24-2008
OK today I added bondo putty to smooth things out a bit, much easier to work with. The dark pink stuff is the putty, Then I sanded the crap out of it.
DSC_0001-4.jpg?t=1203912842
DSC_0002-7.jpg?t=1203912859
The parts sanded/scuffed to be painted:
DSC_0003-7.jpg?t=1203912931
First coat of primer on:
DSC_0005-6.jpg?t=1203913018
DSC_0006-6.jpg?t=1203913063
The dark spots are just where the paint is a little heavy. Two more coats of primer and then paint. Woowho!
Old 02-24-2008
Tape wasn't to terrible to remove, I used a razor blade and a dremel tool. As for the CB, I have no need for it to come out.
Old 02-24-2008
rangeredge_03's Avatar
looks good
Old 02-24-2008
lookin good!
Old 02-24-2008
Looks really good, you'll have a great spot under the CB for switches or gauges or something else.
Old 02-24-2008
Actually the wood is just below the Bondo so it'll have to stay as a big blank spot, but I did think of that... after the fact.
Old 02-24-2008
I bet you could rig something up, you could make a little bracket that holds the CB there instead of having the wood pieces there. Never give up! haha
EDIT: Just thought about it and I doubt you can take the wood out now, with the Bondo there.
Old 02-24-2008
Nope, and I'm not gonna redo it.
I already miss my cup holders and it's only been one day.
Old 02-24-2008
good job! keep it up
Old 02-24-2008
RockysFord's Avatar
i would have done some research 1st, because all that bondo on there will never look right... if it was mine i would have just used fiberglass.. laid it across the front, and then bondo'd over that...
Rocky
Old 02-25-2008
ChrisR1S's Avatar
Lookin good. Are you gonna sand it some and smooth out the rest before you finish primering and painting?
Old 02-25-2008
kyledm18's Avatar
i like how u spread it...lol, looks good!
Old 02-25-2008
Urandaman's Avatar
did you fill the voids with anything before putting the bondo down?
if it is too thick it will crack over time with flexing and heat/moisture.
i would personally sand it a little bit smoother myself... but the concept is cool and i think i will be stealing the idea pretty soon
Old 02-26-2008
I did fill the voids before I bondo'd it.
I sanded it as much as I am going to, the edges look kinda cruddy , but they'll be covered up. I didn't sand it completely smooth because my cup holder and the trim that goes around the CB aren't completely smooth, so I left some texture.
Old 02-26-2008
This is how I was riding for a couple of days:
DSC_0007-3.jpg?t=1204063815
I needed to get the console out so, but I had to take one of the seats out to get it out. So I figured while I'm at it I'll go ahead and take the other one out and clean the floor real good.
DSC_0009-4.jpg?t=1204067271
DSC_0011-6.jpg?t=1204067372
I have to figure out where to remount my airbag switch. Where I had it was blocking my floor defrost vents, which wasn't a problem when I lived in FL.
Old Cb is coming out and will be for sale.
DSC_0012-5.jpg?t=1204067461
Pulling out the trim so I can neaten up all the wiring and rerun some stuff:
DSC_0013-2.jpg?t=1204067504
I cut a piece of metal out of the console to make room for the external speaker. It would have been between my fingers.
DSC_0016-3.jpg?t=1204067519
I had to remove the plastic piece below the coin holder to make room for the speaker and then needed a new barrier in the storage compartment so I notched, fabbed, and attached it in there. It's the piece with the white rectangle sticker on it.
DSC_0017-4.jpg?t=1204067560
DSC_0018-4.jpg?t=1204067650
First coat of paint is on and I will try to post more pictures up tonight.
Old 02-27-2008
ChrisR1S's Avatar
lookin good. not trying to stray too far off topic but hows the Visonic combo work? I installed one in a friends car a year ago when it was a seperate speaker and amp combo and it was kinda umm...quiet. Are they any better now? Im guessing its been redone since that type with the amp mounted on the box is all i see anymore.
Old 02-28-2008
RockysFord's Avatar
I had my subs how yours is... and once i removed the seat, and made a mount for it to bolt down where the seat bolted down its 10x louder... and sounds alot better..
F.Y.I.
finish this biatch up..
Old 02-29-2008
I like it, sounds pretty good to me. Sounds like I should have paid more for it.
On Wed. I picked up the Cobra speaker I ordered, brought it home and the dang thing was to big, so I had to go back to Radio Shack and get their brand speaker same price, 10 watts less, & less toys, Oh well. Any way, it's mounted.
DSC_0002-8.jpg?t=1204327513
DSC_0001-5.jpg?t=1204327527
Never knew what this spot was for or used it, so I figured it would be a good spot for the speaker. It was a very tight fit, no room to play at all. I had to cut some metal and plastic out to make it work.
DSC_0003-8.jpg?t=1204327549
DSC_0004-5.jpg?t=1204327648
Thursday I put the console(less some of the parts I painted) & seats back in and ran all the wires, but for some reason my sub isn't working again probably just a lose connection somewhere.
DSC_0005-7.jpg?t=1204327688
Today:
It's all back in and working(minus the sub). I know it isn't perfect, but I'm happy with it.
I know I still need to clean up the floor.
DSC_0039-2.jpg?t=1204328177
DSC_0041-2.jpg?t=1204328192
The speaker:
DSC_0042-1.jpg?t=1204328236
DSC_0043-1.jpg?t=1204328258
DSC_0046-4.jpg?t=1204328284
DSC_0048-3.jpg?t=1204328312
Man I missed my cup holders! Glad to have 'em back. Well let me know what yall think.
Finished!
Quick Reply: CB Molded Into Expo Console Project
