Sponsored by: DashLynx
Brush Guard + Body Lift???
Old 08-09-2008
Ace's Avatar
Ace
Ace is offline
well is it possible if so anyone got picks on how they modified the brackets?
Old 08-09-2008
Dustin S's Avatar
Mine had brackets that bolted to the frame that had a bracket sticking straight out toward the front of the truck then the brush guard bolted to them, if that makes any sense. I just took a 5x7 piece of 1/4 steel and drilled the frame bracket holes in the bottom then drilled the holes for the brush guard in the top.
Hope that helps you understand it somewhat either way I'll get you some pics up tomorrow.
Old 08-09-2008
Ace's Avatar
Ace
Ace is offline
Ok thanks
Old 08-10-2008
malydeen's Avatar
Um you cant. Send it back to me. I want it back.
Just take the brackets to a fab shop and ask them to cut 3 inches out of the middle and weld it all back together
Old 08-10-2008
Ace's Avatar
Ace
Ace is offline
not sure i understand
Old 08-10-2008
malydeen's Avatar
give me 3 minutes in paint and ill show you
Old 08-10-2008
malydeen's Avatar
Old 08-10-2008
Ace's Avatar
Ace
Ace is offline
wouldnt i need to add 3 inches to it?
Old 08-10-2008
Dustin S's Avatar
Thats what my plate is for to add 3 inches but instead of welding its bolt on
Old 08-10-2008
malydeen's Avatar
no, because the grille guard attaches to the bottom of the frame. The bottom of your bumper is going to get 3" closer to the bottom of your frame.
Its hard to explain.
Everything above the frame is going to get 3" father away from the frame, every thing under the frame is going to get 3" closer to the frame.
Old 08-10-2008
Ace's Avatar
Ace
Ace is offline
that makes no sense to me right now guess ill figure it out when the time comes
Old 08-10-2008
Dustin S's Avatar
I'll post some pics tomorrow. Unless your bracketry is different it will at least give you one option to lift it.
Old 08-10-2008
Ace's Avatar
Ace
Ace is offline
it looks pretty much like he painted in Paint
Old 08-10-2008
Dustin S's Avatar
Mine looks like that to, I'll post pics some time tomorrow.
Old 08-10-2008
WowMike2001's Avatar
Okay, to ease up any ocncerns:
When you do a bodylift.. everythign sits up HIGHER 3" off of the body then normal.
The bracketry for any brush guard is set to mount form yoru bumper, drop it down to right below the bumper, and then wrap around the front end.. if you raise your body 3 inches, that means you need to raise the bracket 3 inches as well.. which, in the case of a bumepr guard, you raise it by cutting out 3 inches of the bracket and re-welding it... which will make it mount higher then normal.
Old 08-10-2008
Dustin S's Avatar
Hmm... not the best pic, but this is how i lifted mine, the frame bracket stayed in the same spot and it lifted the guard 3 in. you can't tell the guards been lifted if you've got your valance on.
EDIT: Yea I know that rubber things loose.
Old 08-10-2008
Ace's Avatar
Ace
Ace is offline
ok thanks i took a look today on mine as well and i think i understand how it works now i thought it was originally connected to the frame.
Old 08-10-2008
Redrocket's Avatar
when i got mine it had a extra set of holes where you bolt it to the frame i just moved it up and used them holes
boyd_835
02-01-2013 10:17 PM
2004xlmiller
How-To & DIY Submissions
04-01-2012 12:49 AM
adamg
01-29-2008 05:02 PM
bpolly_2004
1" & 3" Body Lifts
03-09-2007 12:39 PM
EljayK004
12-27-2005 08:55 AM
Quick Reply: Brush Guard + Body Lift???
