Sponsored by: DashLynx
getting traction in the winter
Old 10-01-2008
yellow_edge's Avatar
YESS....i know its a little early to be posting this..but..ive been dying to ask. what are all you guys doing for the slippery roads coming up. i know ppl that just throw sandbags in their bed all winter. i think i even saw a weight at like stylintrucks that lays down flush in your bed. soo what are you guys doing for thisss im curious to knoww
Old 10-01-2008
DangerRanger#4's Avatar
simple, moved to hawaii!!
Old 10-01-2008
i dont do anything. i personally love to slide all the turns. and then use 4wd when times get tough
Old 10-01-2008
87xlt's Avatar
Slippery roads? HAHA don't have that problem :).
Old 10-01-2008
i would suggest a water bladder my sister used one on her s10 and she loved it put some rv antifreeze solution in it and it worked great.
Old 10-01-2008
Get good tires. I didn't have any weight in the back and I was fine.
Old 10-01-2008
2by4's Avatar
I am just putting 2 2x6's on either sides of the wheel wells and throwing 5 sandbags in between them and I am good to go.
Old 10-01-2008
My91Ranger's Avatar
I've used sand bags in the past, makes it easier to get rolling and I can get moving quicker with them but it also hurt my gas mileage to have 250 pounds of extra weight.
Old 10-01-2008
malydeen's Avatar
Buy a tank....
or build on of these...
I have a tonneau so i wasnt worried about using salt bags but if you dont have a cover i would use sand or you could run into problems with rust
Old 10-01-2008
08XLT4x4's Avatar
thats sweet!
Old 10-01-2008
Prerunner-Ranger's Avatar
Level I Supporter
Teach yourself how to counter-steer and you'll be fine with no sandbags :)
Old 10-01-2008
sand bags are good, never really appreciated them until i drove to work one day with out them and was sliding around. then when i was loaded down with 10 bags of salt at work (snow plowing) and i never lost traction once, ill always have a couple in the back now
Old 10-01-2008
Ranger_Guy15's Avatar
Four wheel drive thats all you need.
Old 10-01-2008
BlutoBodine's Avatar
I was under the impression that my 2008 XLT 4cyl could not be purchased with a limited slip axle, but when I burned out yesterday (just to see if it could) it left two tire tracks. That makes me feel better about the bad weather coming.
Old 10-01-2008
malydeen's Avatar
4wd will just put you farther in the ditch.
Really all you need to do it slow down and drive for the conditions.
Old 10-01-2008
rdoebel's Avatar
In the wintertime I'd just fill the entire bed of my truck with snow and when it melted, I didn't need it anymore
And when I say entire bed, I mean entire bed, almost passed my rear window.
Old 10-01-2008
08XLT4x4's Avatar
yup, they come with LS as an option.
The best thing for snow though is an open differential.
Old 10-01-2008
WORD
Old 10-01-2008
I have been waiting for years to say this!!!!!!!
Old 10-01-2008
But you cant beat 4wd for traction. It really helped last year during the winter.
Old 10-01-2008
Simple, I'll be back in Texas, where it gets to about 50 and that's as low as it gets
Old 10-01-2008
it helps get you going. and thats it
i put mine in 4wd last winter to have some fun and see if i could launch the truck from a stop. i could see 4wd on hills but thats about it.
hell i had never driven on snow or ice until i came here.. i have 12.50" wide Mud terrains.. and i made it through
Old 10-01-2008
Okay, but every time I tried to add the option on the 4 cyl I was always prompted to add the V6 upgrade. Glad I have it though because I'm not the best driver on snow. I use the sandbags for traction also.
Old 10-01-2008
I just drive it how your supposed to and not be stupid. A good set of tires really helps, but then again so does a good driver. My grandfather throws two or three 40lb. bags of concrete in the back of his B4000. I won't put anything else in the back of my truck, I've got enough weight with my toolbox back there.
Old 10-01-2008
Yea thats all I need it to do, get me going. Then once you are going just use common sense and take it slow.
Quick Reply: getting traction in the winter
