AC problem
Old Apr 20, 2008
leadfoot's Avatar
Icon9 AC problem
On a hot day I got into my truck and turned on the AC. It was already 90-95 degrees in the truck. I waited 5 minutes for it to start blowing cold air, it never did, instead it blew hot air like it was on heat at 135 degrees. My temp controll **** had no effect on AC or heat. Max AC works fine however.
The temp control **** tested bad and I got a new one. The problem still persisted. We dicoverd the problem to be a broken valve in the ductwork behind the glove box. The temp control **** controls a white servo, the link from the servo to the valve in the duct is busted. The heater pleum needs to be removed to fix this.
when on Max AC the valve to the heater core is shut, on ac it is open. Is this right? Any comments suggestions or help would be greatly appreciated.
Old Apr 20, 2008
Rev's Avatar
Rev
This might help...
https://www.ranger-forums.com/forum2...heater+control
Old Apr 21, 2008
leadfoot's Avatar
Yep, my blend door link to the electric actuator is busted.
Thanks
Old Apr 21, 2008
leadfoot's Avatar
Thank you I used this link http://www.blenddoorfix.netfirms.com/ and did what they said and now everything works fine.
Free Fix
Old May 8, 2011
morris's Avatar
ok, i have a similar or same problem. max ac works and reg. ac blows hot air. even when i turn the temp all hte way cold. so would this second link
(http://www.blenddoorfix.netfirms.com/) work? the first link comes up 404.
ChargerOnDavins
Oct 3, 2010 05:58 AM
