Ranger Products, Company, & Member Reviews Like a Ford Ranger product? Perhaps a product was not up to par? Did a member impress you? This is the sub-forum for you.
2004 K&N Aircharger
Old May 7, 2005
LILBLUE04FX4L2's Avatar
2004 K&N Aircharger
BEFORE
AFTER
off the line performance is much better Name:  bdsmiley.gif
shifts are smoother
engine seems to be running smoother, like I don't have to give it as much pedal when cruising along
this intake is about 3 inches higher than the intake to the stock air box
I am going to fabricate a bucket type guard to help prevent water ingestion
plan is to modify a 25 pound spackle or joint compound bucket (half size bucket)
this way I can slip it over the collar of the intake and then tighten the charger back on
there are also some screw top frozen chum buckets that might work well also
my first idea was to slip an extension onto the intake and run it upwards over the radiator overflow
unfortunately it will have to head back towards the intake manifold for hood clearance
this will likely cause me to loose the performance gains
the bucket guard with a splash lip and top intake will probably work better
just need to find the right bucket and lid then seal it all up in a manner that is easily removed for street use
anyway - definite performance gains and it is not too loud with the hood closed
performance exhaust is next
OK – talk amongst yourselves……
Old May 7, 2005
CjRanger99's Avatar
Looks good... If you dont mind me asking, where did you get it and how much did it cost?
Chris
Old May 8, 2005
afi_pilot85's Avatar
is that the one that Isn't CARB legal??
Old May 8, 2005
looks awesome neil
Old May 8, 2005
Swoop1156's Avatar
Hey, need some details on how it works with the new embedded MAF on the '04+!
Looks great!
Old May 8, 2005
SoundPer4mance's Avatar
hey, heres what i did on mine for a shield, get you some 8 inch sheet metal ducting, trim to your desire, it slips right over the base of the filter and i held it on with a hose clamp
Old May 8, 2005
r0ng5's Avatar
OOOOOOOOOOOOOOOOOOOOOOOOOOOoo. Too bad it's for the 4.0... Can't wait for the 04 3.0's.... maybe..
Old May 8, 2005
I bought it from Stylin Concepts - $296 including shipping
it shipped directly from K&N in California - no one has them in stock yet
Stylin Concepts did not even know they existed - I got the part number off the K&N web site
no this will not pass California inspection, but I am sure it is just because they are slow handling the K&N request for approval
I would check the K&N web site for the make and model you need - the 2004 models were just introduced and most parts distributors do not even know they are available
Old May 8, 2005
TheForce02's Avatar
no it is not, airchargers are not CARB legal and FIPK's are
the only diff. between the two i sthe CARB certification, the design is edxactly the same. K&N changes the name once they get the certification. my intake took about one year to get certified and once it is you can request the sticker
Old May 8, 2005
so chances are it will become legal for california street use???
im still wondering aboutthe 77 series or something in like an anodized red like the cai's for the 04 4.0's
Old May 10, 2005
Ranger1's Avatar
Whats a matter Neil do you need some more power to turn the big tires ? just kidding. Man that is a clean engine bay. How do you clean that ?
Old May 10, 2005
well Ben more power would be nice, I am not quite sure if this device alone will provide it though
I use the engine cleaning solution at my local quarter eating drive through car wash
looks to be a simple green type solution and I rinse it off plenty good
LIL BLUE has fuel injection, no distributor, former air box (have to be careful with the open filter now)
- about the only thing I kept it away from was the alternator, fuse box and computer
I even wash down the fabric cover, just avoid too much direct pressure and use water only
Swoopie pointed out quite a few cracks and crevices where the dirt and mud can hide in both the engine bay and under body way back in February 2004
thanks Adam Name:  bdsmiley.gif
Old May 10, 2005
RangerJustin's Avatar
For the 3.0
So they are not legal for street use yet, correct???
Old May 10, 2005
Ranger1's Avatar
thanks Adam
I think K&N say they are worth a few ponys not may but a few. I will have to try cleaning mine up one day.
Old May 10, 2005
Ranger1's Avatar
This was run on a 2003 sport trac 4.0L V6 its not a big difference but soom.
Old May 10, 2005
Originally Posted by RangerJustin
For the 3.0
Justin - you provided the link and have read the previous posts.
What do you want to hear because it is very obvious that it is sold for 'off road use'.
Why not send K&N a note and see if they have an expected approval date from the CARB?
IMO I can not see how it would not be approved as it employs the factory MAF and has a connection for PVC.
In NJ they would never know if it was approved or not and we have VERY strict emmissions testing.
They check on a dynometer and use a sniffer to monitor the tail pipe emmissions.
Unless CA pops the hood and looks for any aftermarket parts I doubt you would fail.
It looks the same as a FIPK (name changes after certification) which has CARB certification.
Installing this device does not require you to bypass any factory emmissions settings nor change any fuel calibrations.
Tail pipe emmissions should remain the same, maybe even improve.
Old Jun 5, 2005
Flyinfx4's Avatar
I bought a FIPK air intake kit about a month ago and it is approved and it looks exactly the same as the one you put on your truck.
Old Jun 5, 2005
Flyinfx4's Avatar
Hey i have a 2004 ranger fx4 level 2 also except ts a manual where did you find a place to mount that cb.
Old Jun 5, 2005
no expected date as of now for it becoming CARB legal...
blastindatrails
17
Jun 5, 2011 07:34 AM
Betts138
Jan 16, 2010 01:19 PM
05BLKEDGE
OLD - Engine & Drivetrain
Sep 13, 2009 11:56 PM
RangerJustin
Aug 30, 2005 05:00 PM
