Sub Box Question - Need some opinions
Old Dec 24, 2005
02FordFX4's Avatar
I have a 10" Rockford Fosgate Punch HX2 sub that requires a sealed box of .2-.75 cu ft. I meant to buy a box that was .7 but somehow I screwed up and bought a box that was 1.0 cu ft. Because this is out of the range of the recommended specs, will this make my sub sound horrible and will I be better off shelling out more money to buy a new box?
Thanks,
Jay
Edit: I have a sealed box not a ported box. Not sure why I said ported
Old Dec 24, 2005
wanted's Avatar
YOU may not notice a difference.
I have yet to hear anything in a universal ported box that is tolerable to listen to.
Port length affects sound
Port size affects sound
Old Dec 24, 2005
86YOTA's Avatar
This box will actually make your sub sound better if anything. Going over is ok, its having less that it bad.
Old Dec 24, 2005
Rangerboy03lvl2's Avatar
i have 2 of the same subs, i have a box that is 2.5 cu ft with a divider in the middle so 1.25 cu ft for each sub, this box was designed for a different set of subs. the other day i made a new box that was within the spec for these subs it ended up being right at .80 cu ft for each sub. it sounded like *** compared to my old box, so none the less the old box is back in. i think it will sound great with the 1 cuft box you got.
both my boxes were/are sealed
Old Dec 24, 2005
02FordFX4's Avatar
Thanks for the info guys. I'm gonna keep the box and see what it sounds like.
Old Jan 13, 2006
3906brad's Avatar
To kind of continue with this, I am wondering what would be better. I guess this is where it turns into opinions more than what actually is better, but I dont care. Opinions please.
Sealed or Vented?
I like Vented, but I heard a good sealed box tonight. please help!
Old Jan 13, 2006
wanted's Avatar
When they are built correctly, for the REAL range of the driver (not what the box says, but rather the REAL range), a ported encloser will kick a sealed enclosures *** all day long.
But, a ported box is a lot more complex. Diameter of port, length of port, side of box, etc, etc. And nothing gets down low like wood.
Old Jan 17, 2006
a_shane2_go's Avatar
I agree with going over is better. I remember a buddy of mine that had two 12's and two 10's in a custom box (in and old Ford Mustang hatch back) The subs were ****ty used (litterly like 100$ canadian for all 4) and then like a 400Watt amp and well it pounded, Y, the air behind it. (It was sealed.) so yeah i say if you have the extra air its a good thing for sealed. As for Ported i dont have that much expereince, but i'd think it would throw off the tuning etc.
Old Jan 19, 2006
jojosdad's Avatar
My opinion..... sealed .....if you like tight more accurate bass, ported if you want to sound like those guys you can hear coming 2 blocks away.
pushdeck
May 2, 2010 10:39 AM
MugenCRX04
Jan 8, 2010 05:02 PM
WowMike2001
Jul 11, 2008 06:45 PM
crucialcolin
Audio & Video Tech
Jun 21, 2008 09:13 PM
redranger_02
Audio & Video Tech
Feb 14, 2007 05:00 PM
