Stupid door dinger......snip a wire???
Old Sep 6, 2005
<New post at bottom>
Hi.
I'm tired of cleaning out my truck or partying with friends w/ driver's doors open, listening to the radio(ign in accesory) and that dang dinger going off. With the passenger side open, no dinger w/ radio on. DING DING DING DING DING....IT DRIVES ME NUTS!!!!
Is there a wire that I can disconnect or anything I can do to make the dinger stop?? I know it's for safety, but I did do the seat belt chime delete, and ALWAYS wear my seat belt...so safety's okey.
Thanks!!
Shane
Old Sep 6, 2005
Yea I hate that crap too. And its only the drivers door!
Old Sep 6, 2005
SuperGildo@RRP's Avatar
open your hood, locate the battery snip the red side of the battery, then snip the rght side of you battery and touch the two battery side snipped ends together on your tongue...
Old Sep 6, 2005
aftermarket's Avatar
If you push the latch on the door in, then the chime will stop ringing.
But can't close the door, you have to pull out the latch if you want to.
Old Sep 6, 2005
I do it all the time when washing my truck and want to hear some tunes!
To pull out the latch to close the door and have the chimes again, use a key or screwdriver to do it.
Old Sep 6, 2005
Gil....you freakin' crack me up
Old Sep 6, 2005
Swoop1156's Avatar
It's really simple. There is a red/grey wire behind the radio connected to the GEM [I think it's the GEM]. Tap that into the yelow/black wire so it thinks it is the passenger door, that way, the light and door ajar dash light still comes on, but the door dinger is dead.
Verify with the door dinger mod. I am sure it's here, there or somewhere.
Old Sep 7, 2005
G-E Dinger Mod for 2003-back
Old Sep 7, 2005
Swoop1156's Avatar
Now that's what I'm talking about, Bob! Nice link!
Old Sep 7, 2005
Credit goes to Colin (Draimen) who had the foresight to save some of the how-to's before G-E went under.
https://www.ranger-forums.com/forum2...89&postcount=8
Old Sep 7, 2005
Swoop1156's Avatar
I have some saved, but they are on my laptop, and I don't have my laptop. I don't know how many I have saved, but that's a good amount of them right there.
Old Sep 7, 2005
00RANGER00's Avatar
i put my key to "ON" w/o starting it and it dings for a few seconds and then it stops.......dont know if that helps.
i figured that one out one day cleaning up the truck.
Old Sep 7, 2005
Bigwill41's Avatar
I done this mod ..
Love it...
Old Sep 7, 2005
Guys....thank you very much, this mod will be done this weekend. Thanks again!!
Shane
Yea...I won't do that for the fuel pump turning on....all the lights on, draining the battery...heater/ac on.
Old Sep 7, 2005
I will have to do that!
Old Dec 5, 2005
Guys....please don't bash me for thread diggin'.....but. I WAS STUPID. I didn't print off what I needed to when I could have months ago, now the links don't work. Does anyone have the how-to to dump the door dinger w/ accesorie circuit is on & driver door is open??? I think one of the links had good pics for this mod.
THANKS!!!
Shane
Ya'll...I apoligize.
Old Dec 5, 2005
Hey, that's one of my mods (well, not much of a mod anyway, lol...)...
I never did it, I just described it and I think someone else did it. I did post GEM connector pics though. I don't know what I still have in the archives...
Old Dec 5, 2005
Note: Edited due to reversing the wire colors. The text below is NOW correct, but check it if you printed it earlier, or just look at Bob's post below.
The stuff is there in the directory Bob linked. Here's some pics and actually I did take these apparently:
This pic shows the connector to use:
This pic shows the two wires of interest teased out from the harness:
And Adam already told you what to do. CUT the yellow/black wire but leave a bit sticking out from the connector so you can reverse this. The piece that sticks out from the connector you should "tape off".
Now take the black/yellow wire from the harness and scotch-lok it (tap it into) the red/gray wire. Now both doors are on the passenger side circuit.
That's it.
Old Dec 5, 2005
Here is the complete text of John's original How-To for the Door Dinger Mod. It should work for several years up through 2003.
Written By: John Griggs (N3ELZ) and Hunter Southworth.
Some folks have expressed an interest in being able to disable the door dinger chime without losing their dome light and door ajar functions. This mod does just that. Here's what it does. Some have reported that their passenger side door sets off the door chime as well. If your truck does this, then this mod won't do you any good.
• If you leave your keys in the ignition with the door open, there will be no chime.
• If you leave your lights on and the door is open, there will be no chime.
As with any mod that involves the electrical system of your truck, you should disconnect the negative cable from your battery to avoid any damage to the electrical components during the procedure.
Tools:
• Wire cutter (both procedures)
• Ford radio removal tools -- OR -- a 9/32 or 7mm socket and driver handle. (both procedures)
• Wire stripper (alternate procedure)
• Crimping tool (alternate procedure)
• 1 tap connector (standard method) or 1 small gauge butt splice or wire nut (alternate method)
1. Remove the radio or center console piece. You may either use the Ford radio removal tool to take out just the radio, or you may take off the center console by removing the two hex head screws just above the heater controls. If you remove the radio, remove all connectors and carefully set the radio aside. If you remove the console, use the 9/32 or 7mm socket and after taking out the screws, pull the console STRAIGHT out. Disconnect the wiring from everything and set the console aside.
2. To the left, mounted on a wall between the gauge area and the center console area is a black box with 3 connectors going into it. This is the GEM or generic electronic module as shown in the photo below.
3. One connector is the largest and has 26 pin positions. Another one (the one closest to you when you look at it) has 18 pin positions, and it is the one overhead console fans know as the one with the VSS wire on it. The third connector has 16 pin positions, but only 2 are used. We want the largest one, as shown by the red text in the photo above. It's easiest if you unplug it from the GEM.
4. About midway along this connector are a yellow wire with a black stripe (YE/BK) and a gray wire with a red stripe (GY/RD). They are RIGHT NEXT TO EACH OTHER and if you find those colors NOT right next to each other, you're on the wrong connector! These two wires are the two wires we're interested in. NOTE: for the standard procedure, proceed to step 5, for the alternate procedure, go to step 7.
5. Cut the YE/BK wire, but do it far enough from the connector that you have a 2 inch or so stub left on the connector in case you want to splice it back later. Tape the end of the YE/BK wire stub hanging from the connector.
6. Now connect the cut end of the YE/BK wire that goes into the wiring harness (not the one hanging from the GEM) to the GY/RD wire, using a tap connector. You're done! Reassemble everything, being careful if you have the 6CD changer to hold and keep it level when you attach the main connector.
Alternate Procedure:
7. Cut both the YE/BK and GY/RD wires, but cut them back about 2 inch or so from the connector. Tape the end of the YE/BK wire stub hanging from the connector.
8. Strip the remaining 3 wire ends and connect them all together using the butt splice, wire nut, or other method (such as soldering). Make sure the result is insulated when completed. You're done! Reassemble everything, being careful if you have the 6CD changer to hold and keep it level when you attach the main connector.
Old Dec 5, 2005
Thanks, Bob! Lack of foresight on my part: I never saved a complete copy...
Edit: and OOPS -- Adam and I (well, I took his lead lol) had the wires backwards. READ THE HOW-TO BOB JUST POSTED. I'll go back and fix my other post....
Old Dec 5, 2005
(907)FAN-BOY's Avatar
Yea I hate it too. On my truck I can move the key forward to right before it goes switches to not giving power to the stereo and it'll go off. Easy and you can still keep it without messing with anything.
Old Dec 5, 2005
During the short time I was on G-E, the Dinger Mod was only posted on rangeredge.com but that site no longer has a functional How-To section.
John, would it possible to add this to your CarDomain site and/or submit it to the How-To Forum? It needs to be available as a permanent How-To somewhere.
Old Dec 5, 2005
Mr. Special's Avatar
sweet! hah well i will thank you Shane for bringing this topic back to life, cuz i will now be doing this mod
Old Dec 6, 2005
I guess I'll put it on CarDomain -- I put a lot of them there because then I know they're somewhere I "control" to some extent (although that whole site could disappear overnight, lol).
I'd be perfectly happy to see it put up here. I don't think Hunter is around anymore, but I'd like his name to stay on it.
What happened is, he asked about doing it, and I described, with no pictures and in very abbreviated terms, what to do and he did it and tested it out. I thought he deserved some credit for that even if I did write it up.
Old Dec 7, 2005
Bob, Mr Griggs.....THANK YOU VERY MUCH!! Big help.
Shane
