throttle slack
Old 08-17-2004
BananaEdge's Avatar
MORE PICS!!!!!
ok i just got back from the track and found out that i have slack in my throttle linkage and was wonderin how to tighten it up any?
Old 08-18-2004
3LiterBeater's Avatar
Get down under the throttle pedal and find the cable... zip tie around the cable until the slack is gone...
Old 08-18-2004
BananaEdge's Avatar
any other ideas dont exactly know what u mean
Old 08-18-2004
The throttle pedal pivots, at the top of the pedal assembly the cable runs through the firewall and to the pedal. The cable runs through the pedal and through a spring. After this spring there is sometimes slack in the cable... If there is slack, pull the cable tight (without opening the throttle body) and put small zipties around the cable until the slack is gone. Get down there and look around, its pretty self explanatory once you look at it and is a quick and easy fix to your problem...
insistent
08-11-2014 02:37 PM
TORQUERULES
61
07-22-2010 08:43 PM
Taylor
04-13-2010 07:44 PM
schatten789
09-20-2008 06:54 PM
dangelj316
34
11-17-2007 12:41 AM
Quick Reply: throttle slack
