Where to buy ring and pinions ?
Old Jan 20, 2006
Ranger1's Avatar
Like the title says, I am ready to upgrade my ring and pinion. I have decieded to go with 4.88. My towing demands have gone up and according to TRS's gear ratio calculator I should go with 4.88. Where is a good place, and whats a good price and brand ? Does Ford make a 4.88 gear set for our rangers ? I don't think it will be hard to find a set of the rear but I also need a set for the front.
Old Jan 20, 2006
This is the guy I used for my axle stuff when I built it. I got the locker, gears and rebuild kits all from him.
Jeremy Ayers, J.T. Parts and Accessories (Specializing in Differential Parts and Service)
Phone: 425-879-6192
email: jtsdifferentialsaxles@comcast.net
Website: http://www.ringpinion.biz
Old Jan 25, 2006
Ranger1's Avatar
Did he install them or did you do them ?
Old Jan 25, 2006
theres also a place called www.summitracing.com lol...now i could be wrong but isnt the front diff on the newer trucks the highest you can go is a 4.56? once agian i could be wrong
Old Jan 25, 2006
034x4's Avatar
Got all my stuff from Classic City Off-Road. 706-207-4140.
Ordered everything ~11 am on monday got it at 12 am the next and I payed regular ground shipping.
He will match/beat prices so shop around before you call. Great guys. I always deal with Bobby.
Old Jan 25, 2006
SoundPer4mance's Avatar
i can get all your ring and pinions, right now i am pricing up a few sources, and i should be able to go
Old Jan 25, 2006
ryanrebel125's Avatar
4wheel parts and ebay.
Old Jan 25, 2006
looks to me your truck is 4wd. if it is you will never find a set of 4.88's for the front. you will only find them for the rear. yea you can put in larger than a 4.56 in the front. i have a buddy who has a 5.13 in the front of his '00. i would go with the 4.56 in your truck.
the best place to call about infoand gears that can tell you what gear you need to run is 4 Wheel Parts. They will ask you some questions about your truck and tell you what you need.
Old Jan 25, 2006
mcerwing's Avatar
randy's ring and pinion
Old Jan 25, 2006
Ranger1's Avatar
Hey I contacted Griggs's guy and he is asking me what front diff I have. I thought they were all the same D35/28 hybrids. He says "I would think that your truck should have the Super Dana 30 which is what an 03 Explorer has in it"
So whats up with that ?
Old Jan 25, 2006
you have a Dana 35 standard rotation front end. Ford put the Dana 35 standard rotation front diff in the Rangers in 98 with the torsion bar suspension. pre 98 Rangers either have a Dana 35 (found mostly on1990 and newer) or a Dana 28 (weaker, and found on FEW 1990 and newer but mostly used on the 1990 and older).
when the person you talk to ask what front end you have tell them you have a "Dana 35 Standard Rotation".
Old Jan 25, 2006
Ranger1's Avatar
Anyway to look that up and be sure before I order them ?
Old Jan 25, 2006
SanityAside's Avatar
you should go with bob
Old Jan 25, 2006
i am 100% sure what i told you about your front end being a Dana 35 Standard Rotation front end.
Old Jan 26, 2006
this here should help
http://www.precisiongear.com/dana35.htm
Old Jan 26, 2006
Rand's Avatar
its a 4.88 gear for the front.. good link zach.
4.88's are needed to simply maintain the factory ratio..
it comes with 4.10's and 31's
Old Jan 26, 2006
nated0g's Avatar
very interesting that the same dana 35 for jeep rears is the same for the front. sounds like it would be easier/cheaper to get lockers and or gears.
Old Jan 26, 2006
034x4's Avatar
I would never trust 4wheelparts with gears/install kits. I know all the guys at my local 4wheelparts and no way. Half the time you order stuff you get the wrong parts anyways. When I bought my winch the box was destroyed and the handle on the clutch drum was broken off, and wasn't even in the box, and they wouldn't do anything to fix it.
I only buy tires from them, cuz they are the cheapest. Except now a friend works for discount tire and I can use his discount.
Old Jan 26, 2006
I did the install "with a little help from my friends".
See here: https://www.ranger-forums.com/forum2...ead.php?t=6064
Tys 4x4 FTW
Dec 1, 2009 12:44 PM
Yessick
Apr 7, 2008 08:11 PM
therangerofdanger
Apr 18, 2007 11:26 AM
Ranger1
19
Aug 9, 2006 09:34 PM
DaytonaBchRanger
Oct 5, 2004 05:49 AM
