Bad night
Old Jan 31, 2006
seneca's Avatar
Bad night
Last night I installed new spark plugs and plug wires. when i finally got done and cranked the truck, something started squelling. come to find out one of my pullys, not sure which one yet due to lack of light, is going out and screamin its head off. can i buy just a replacement pully or do i have to buy what the pully is attached to. Also, where can i buy a new pully and it not cost an arm and a leg. thanks in advanced for the help.
Old Jan 31, 2006
mx98ranger's Avatar
i would try to spray some wd40 in it or something first...
Old Jan 31, 2006
Morph's Avatar
My pulleys strated squeaking to high hell one day too. I bought a new belt and a new Idler pulley. The idler pulley wasnt bad, but it was the ALternator that was sqeaking. I called the parts store and they told me I'd have to replace the whole thing, not just the pulley. I guess It depends on which goes out. Also, I just put the new belt on without changing the alternator and the sqeak went away. Try that first. Might as well replace it anyways.
Old Jan 31, 2006
seneca's Avatar
the belt is brand new and i've already sprayed WD-40 on it. it stops the squel for about 5 minutes then it goes back to the way it was.
Old Jan 31, 2006
graniteguy's Avatar
Replace the idler pulley. It's usually the idler or the belt.
Old Jan 31, 2006
seneca's Avatar
i'm going to get the serpentine belt tool from autozone so i can check to see what pully isn't turning. i'm guessing it's the idler pully because it is starting to get some wierd looking marks on it that were not there a few days ago.
Old Jan 31, 2006
seneca's Avatar
also the idler pulley is $30.00 from autozone also with a 3 month warranty.
Old Jan 31, 2006
Morph's Avatar
Nonsense! I payed $15 for mine. Didnt need it and brought it back. And to tell which is sqealing, just take the belt off and start spinning them individually, thats how I found mine.
Old Jan 31, 2006
seneca's Avatar
were did you get it from and would it be better to buy a new one to go to auto-pull-it store and get one
Old Jan 31, 2006
Morph's Avatar
I got mine at a local Pep-Boys, dont know if they are nationwide or not. I think it'd be better to get a new one, you could spend $10 on one from a junk yard, and get home and it would do it again. Make sure its that pulley before you replace it. Mine sqeaked when I spun it with my hand. Mine too would go away for a few minutes when I put belt dressing on it, but would promptly come back.
Old Jan 31, 2006
seneca's Avatar
Alright i went and pulled the belt off and rolled each pulley and my idler pulley is fine. but unfortunatley its my alternator is the one squelling. the cheapest one i've found was $124.00 with a lifetime warranty.
Old Jan 31, 2006
Morph's Avatar
Same thing happened to me. In that case, I'd just go to the junkyard and get an alternator. Although with a new belt, it quit doing it. If you've got a new belt, I guess that leaves you with finding another alt.
Old Jan 31, 2006
seneca's Avatar
I would much rather just spend the extra money on an altenator that I can have a lifetime warranty on it
Old Mar 10, 2006
midnightedge's Avatar
You know, I just now read this post and my truck does the same thing. Did you replace the alternator? Did the noise go away? Has anyone else have similar problems/results?
Old Mar 13, 2006
seneca's Avatar
i haven't replaced it but i did take the pulley off the altenator and spray wd-40 down into the alternator where the pulley connects and it shut up. now and then it does make a little noise but other than that its been good.
Old Mar 13, 2006
mkoenig's Avatar
My idler pully squeaks at startup, usually only after a heavy rain; maybe the humidity in the air, or the fan spraying water at the idler causes it to squeak.
I had the right-side fender liner out this weekend to change the spark plugs. Easy access to the idler pully when the liner was out... should have changed it then!!
Old Mar 13, 2006
park ranger's Avatar
life time warranty on an alternator... take it!!
LayingFrame89
Ranger Products, Company, & Member Reviews
34
Dec 1, 2007 06:59 AM
MonsterGuy
Aug 6, 2007 03:29 PM
ranger
32
Jul 31, 2007 11:50 AM
FMD
Apr 25, 2006 07:21 AM
