Simple trick to ease lower ball joint installation
Old Oct 11, 2006
This may have been posted before, and it's common sense really -- but I never did it this way and I'm kicking myself for it, lol.
I put the new ball joints in the freezer for 15+ minutes before I installed them and took each one out only after I was ready to put it in. I lubed the hole in the lower arm and the ball joint with a thin layer of silicone grease (Sil-Glyde brake part lube).
Well, it took so little torque on the ball joint press that I was astounded. I've put quite a few sets of these in various Rangers and this is the easiest it's EVER been by far.
Like I said, cooling a press-fit part to make it go in easier is not news -- but somehow I never applied it to ball joint installation, so I thought I'd share it anyway.
Old Oct 11, 2006
huh good idea... ill have to try that whenever i do mine
Old Oct 11, 2006
Alon's Avatar
could even heat up the lower arm if you really wanted to
Old Oct 11, 2006
04lvl2's Avatar
Definitely a good idea, heating the arm though Alon is not something I would want to do as it would weaken it.
Old Oct 11, 2006
I'm with Bill I'd be worried to heat the lower arm, but freezing the joints is a good idea. I'll put that one in the idea chest if I ever need to replace mine.
Old Oct 12, 2006
Alon's Avatar
i'm not saying to get it red hot, just a little warm.....
Old Oct 12, 2006
shadyluke's Avatar
I understand heating it Alon. I have seen it done and it works well. I just hate working around hot objects.
Old Oct 12, 2006
I just use a balljoint press and have no problem.
Old Oct 12, 2006
It depends, Andy, on how dirty/corroded they are. It doesn't help getting the old ones out, that's for sure. But it's still easier and quicker getting them in and it's pretty much free.
I found on Candice's truck (8 years old), that I had some difficulty with the new ones because I didn't clean up the arms first. That's probably as important as anything else.
Still need a balljoint press regardless. Easier is easier, says I, lol.
Lefty04LevelII
Jul 11, 2009 05:19 PM
Brando5105
17
Dec 6, 2007 06:13 AM
jtslmn720
32
Jan 12, 2007 08:36 PM
Hitch
Dec 26, 2006 07:17 PM
Roach2004
Nov 18, 2005 06:35 PM
