E-fan offroad damage, repair, and recommendations
Old Dec 11, 2006
Some of you wanted to know how I mounted my e-fan in my shroud, well, the pics below should tell you -- it's a "Griggs Rig", lol...
As you can see, I lost a blade. This is why I think offroaders should use only fans with an EVEN number of blades. If you break one, you can break off the opposite one to restore balance. With odd numbered blade fans, this is a pain. Sawred (Mike) broke one back in April and ended up with like a 3 blade fan or something before he had it balanced.
As you can see, I broke off the opposing blade, and the fan runs true again.
Also, I had epoxied in the mounting pieces to the fan housing and two of them broke loose from the vibration. You can see what I did in one picture with some metal clips I had in the junk box. It keeps the slide-on mounting tab from sliding off the back of the fan.
When the fan was vibrating so badly, it pulled loose the silicone rubber sheet I used to fill the void between the 16" fan and the 18" shroud. That piece came out from the housing and rubbed against the tensioner and got a hole worn in it. You can see it looking "shredded".
It's back together and running true. It's been in there for quite a while with no problems, but when I was offroading a week or so ago I left the fan on continuous run when I hit a hole. Usually, when you're running at holes the engine is so cool your fan doesn't run, but not this time. In the dark I must have hit that switch when I was reaching for the locker. I know I looked and saw the locker was still on and didn't know how that was as I remembered turning it off.
This is a good case to be made for Winks "fan on" indicator.
Sorry about pic quality. I was doing the repair in the dark tonight.
Old Dec 11, 2006
IronRanger92's Avatar
thats pretty sweet.. shame when something breaks and throws the whole thing off track.. pretty sneaky to with it loooking stock like that
Old Dec 11, 2006
graniteguy's Avatar
After being stranded on the side of the road from over heating, the fan on light is a must.
Old Dec 11, 2006
Ha ha! That's enough of a testimony for me! (along with my own experience, lol...)
Old Dec 12, 2006
winks's Avatar
Yay, does this mean I get a gold star next to my name for good work??
This is a link to what John is talking about if anybody is interested, click here.
Old Dec 12, 2006
I've got an old "Gold Star" brand VCR in the basement you can have...
I should have put one on, but I wanted it to run from the actual power going to the fan, after the fuse, and I was too lazy to run one more wire, lol...I paid for it.
elutheros
Engine & Drivetrain
Jul 19, 2023 08:08 AM
Dbuser2
May 18, 2015 08:50 AM
wickedsprint
Mar 31, 2012 07:24 PM
CaptainScarlet
19
Mar 19, 2006 04:08 AM
n3elz
38
Nov 1, 2005 04:34 PM
