Power Mirror Wiring?
Old Jan 21, 2007
heaton84's Avatar
Hey guys,
I just got everything rounded up for my power window conversion... inserts, actuators and wiring. I'm in the planning phase and am modifying the harness that runs between both doors to also include the wiring for my locks (figured I'd condense that stuff, make it more professional and likely more proper).
Now, here's the issue... the driver's side insert has a switch for power mirror adjustment, and down the line I would like to get power mirrors as well. The switch has about 7 wires coming out of it... I've tried figuring the pinout with a multimeter and continuity sensor, but havn't got very far. Considering I don't even have the mirrors yet (or the budget to get them at this point), I was wondering if anyone knew what wires I needed to run to the passenger-side door for mirror control (may as well do it all now while the harness is out of the truck). Anyone able to help me out?
Old Jan 21, 2007
pin 7 orange/light green (12v power)
pin 5 black (ground)
wires from switch to passenger mirror:
pin 2 pink
pin 3 dark green
pin 6 yellow
wires from switch to driver mirror:
pin 4 dark blue
pin 1 red
pin 6 yellow
Old Jan 21, 2007
heaton84's Avatar
pin 2 pink
pin 3 dark green
pin 6 yellow
pin 4 dark blue
pin 1 red
pin 6 yellow
Thanks, Bob!
Old Jan 23, 2007
DaneTrain's Avatar
Heaton...I'm trying to do the same thing. Can you take some pics of your progress?
Old Jan 24, 2007
heaton84's Avatar
Sure will. Gotta find a host for the pics first (no longer a college student, no more free webserver).
Tested the setup tonight on the living room floor. She works! Had a spot of trouble... looks like the p/s harness isn't making solid contact... gonna have to work on that...
Old Jan 24, 2007
Cool, ive been wanting to do that to mine for a while, how much did all the stuff cost you?
Old Jan 24, 2007
heaton84's Avatar
The window kit ran me about $150 on eBay (came with the harness and two regulators). About $75 total for the inserts (probably a bit high but I really wanted a stock look). The stuff for the power locks (RKE receiver/controller and both actuators) ran me probably $50. So I'd say about $275 to do the whole thing (and that's not factoring in the spools of wire I bought to help integrate everything.)
Edit: forgot a parentheses.
Old Jan 24, 2007
heaton84's Avatar
A picture of the harness before I operated on it (came with the kit)...
Passenger side insert wired up for a test...
If you look *real* close, you can see the yellow and orange wires I added for lock commands, as well as the green/blue (not terminated yet) for the lock actuators and the three unterminated power mirror wires.
And the driver side...
The windows currently test out OK. Since spring is so far off yet, I'm thinking about putting a twist on this mod... I'll go into that more later if it pans out...
briz
Apr 30, 2010 09:17 AM
Jp7
Oct 29, 2009 05:21 PM
speedranger
Oct 16, 2009 05:38 AM
malydeen
Jun 9, 2009 08:30 PM
malydeen
Apr 21, 2009 02:27 PM
