Sponsored by: DashLynx
CEL, Gas Gauge Acting Funny, and I'm wondering what's going on!!!
Old 01-22-2007
jrpro130's Avatar
I can get my hands on a code reader, so I'll find out the code shortly. My gas gauge will fluxuate from 1/2 to commpletely (like over the F) filled. It seems like I just have some bad gas?
I got hess, which I never get b/c of the quality. I'm going to try Mobil in a minute (I'm about 1/4 tank..guestimate). See if that works.
This damn truck is giving me a huge headache. If the transmission wasn't enough!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!
Old 01-22-2007
ranger024x4's Avatar
stsy out of lakes then.. lol
Old 01-22-2007
The quality of the gas won't affect your gas gauge. You've got an electrical problem of some sort. My guess is your CEL will relate to the EVAP system and you'll find something damaged around your tank somewhere.
Old 01-22-2007
jrpro130's Avatar
Dangit...I knew I need to stay out of the water. Electrical problems are the last thing I want.
Now I want to sell the truck...it's like something breaks everyday. Thats what I get for beating it up offroad though.
Old 01-22-2007
Get the code read... they do it for free at advance auto...
remembering how deep you were i wouldnt be suprised if the charcol canister is bad
Old 01-22-2007
I've had the rear in that deep and no problem. I'm more concerned that something rose up underneath and whacked something.
Old problem someone has was with dual-outlet exhaust where the pipes ran too close to the plastic lines to the cannister and purge valve.
Old 01-22-2007
jrpro130's Avatar
Yea, my rear end was completely under water. No bed rails could be seen (except for the very front stake holes. The water was at the window line splashing basically (before she settled).
The steady water line was below the door handle.
I was at such an angle too...the gas tank side was up.
I bet something hit it. I go over quite a few rocks and sticks and trees.
Old 01-22-2007
Well, I've never been quite that deep, lol. It could be something like water in the EVAP system -- should be easy to purge though.
Guess it starts with an inspection under the truck -- wear safety glasses, lol -- mine drops crap on me no matter what I touch under there...
Old 01-22-2007
jrpro130's Avatar
Well, code P0460.
It's the fuel something or other (I forgot). I cleared the CEL, it hasn't came on for about 15 miles now. It takes 2 times for that one to trip, so I'm thinking it should trip soon. I read a post bob posted before on it, I'll search again and post it in here to make it easier for other people
Old 01-22-2007
jrpro130's Avatar
Old 01-23-2007
Well, code P0460.
P0460 = Fuel Level Sensor circuit voltage level out of range.
Did you check the 40-pin connector near the transfer case and the 4-pin connector at the fuel pump assembly? Open them up and look for water or corrosion inside. Clean/repair as necessary and repack with dielectric grease.
Originally Posted by rwenzing
The Fuel Level Input is a single wire from the fuel pump assembly to the PCM with a branch to the cluster. I think this code would probably be triggered for a short or open that pushed the voltage out the range that would be normally seen by the PCM for a healthy FLI.
...the first place I would check would be the large 40-pin connector under the chassis directly below the driver seat. It is fairly common to get water and/or corrosion in that connector which can cause a variety of problems on circuits that go to the rear half of the truck. I have that connector packed with dielectric grease in the hope that it will keep the water out.
Old 01-23-2007
01xltranger4x4's Avatar
T-case? I thought he was 2wd.
Old 01-23-2007
You got me there. I guess I must have been thinking that no one with a 2WD (except John!) would get that submerged.
It doesn't matter if it's 2WD or 4WD, though. His truck has the same connector in the same place. It is under the cab directly below the driver seat.
Old 01-23-2007
HEY!!!
Old 01-23-2007
jrpro130's Avatar
Awesome! Thank you very much.
Ranger-forums has yet another crazy ranger guy...so mark that as 2 guys who sink their rangers weekly!!!
I'm trying not to do it again, but the next time it does happen, I'm doing the herculiner mod. I don't liek the vynl floor, it's too much of a pain to clean.
And hopefully I'll either be buying a 4x4 or converting mine with a solid axle VERY soon!!!!
Thanks once again bob, I'm going to look at it right now!
Old 01-23-2007
jrpro130's Avatar
Got it!!!
Found the problem...there was about a pint of water in the connector. Along with mud. I cleaned it out and I"m letting it dry now.
It seems as if when the connector is unplugged, the fuel gauge reads completely full. So it is a problem with the connection that is making my gauge funny.
Here's pics to elaborate....
This was during...before it was completely off
Gas Gauge (I have little over 1/2 tank)
That was a span of maybe 10 seconds.
Old 01-23-2007
Good pics and good job. Don't forget to get some dielectric compound, or a good substitute is NOALOX or something from a hardware store that is for aluminum wire connections to non-aluminum. It's not expensive and it works excellently even on totally non-aluminum.
I think mine is coming apart. I remember Bob's original post about back-filling it with compound and I MEANT to do that, but never got to it.
Old 01-23-2007
jrpro130's Avatar
Dielectric compound is coming! I'm going to get it as soon as possible. The pics don't even explain how much came out of there!
This needds to be added to the mods of any offroaders...same thign as the vent extensions.
Man, I'm learning the HARD way on everything!!!! No vent extensions=tranny blows, no dielectric compound=cel and gas gauge weird
What next?
Old 01-23-2007
bwester04's Avatar
I figured that was the problem.. that happened to me after just going through big puddles of water- I would get ABS lights, brake lights, CEL's.. I think there needs to be a sticky on this troublesome connector. Glad you found the problem!
Old 01-23-2007
Got it!!!
Good job!
Water/salt/mud in that connector can cause problems with brake, running, turn and backup lights, fuel pump/fuel gauge, evap codes, ABS, and, on certain years, erratic speedometer behavior and auto trans shifting - in other words, it carries the wires for everything electrical that lives in the back 1/3 of the truck.
If you get salt water in there and don't catch it soon enough, the pins will corrode and literally dissolve inside the connector. This can be a big problem where road salt is used.
Using generous amounts of dielectric compound is a step in the right direction. I think those who live in the rust belt or offroad through deep water should check the "fluid level" in this connector on a regular basis.
Old 01-23-2007
It's on my list now, that's for sure...now if I could just find my list...
Old 01-23-2007
jrpro130's Avatar
Good job!
Definetly! I'm going to get the dielectric compound now.
It was still rising (the gas gauge) when I plugged it in about five minutes ago. It seems like it may be false grounding or something? Should the compound help that?
Old 01-23-2007
jrpro130's Avatar
It's fixed now. The CEL went again, but the gas gauge works, tranny is shifting better now, truck just overall seems smoother. No ping, no noises, nothing anymore. (I was pinging before).
I put the dielectric compound on it, at first it was all weird (running) but now it is running fine.
Thanks John and Bob!!!
Old 01-28-2007
jrpro130's Avatar
Ok, it's back to it's old self. CEL, gas gauge going crazy. What is the next step?
Old 01-28-2007
Sonic_03's Avatar
lmao..man..how bout you jsut trade her in and no more pretending your a submarine!! lol were all learning from your experiance haha or just drive faster next time and youll skip across the top of the water LOL..i hope you get everything fixed!
Quick Reply: CEL, Gas Gauge Acting Funny, and I'm wondering what's going on!!!
