Rcd New Coilover Shocks
Old 02-03-2007
BIGDREAMER02's Avatar
I have been looking for some new coilover shocks for my truck. I have a 5.5" RCD lift on my 4wd. I got it nearly 2 months after it was released, and get this, I got the entire thing for $2300 installed. True story. The guys at the shop had no idea that it involved as much work as it did, and since it was there first time intalling this lift they gave me a little break. They said next time they install it, it will be like $2800 or more.
Anyways, I have been looking for some new shocks on the front end since mine are sagging a bit, and after 29k, a bit stiff. I have been playing phone tag with RCD a bit but finally got the specs on the front shocks.
They are bilstein 5100's that are obviously a special coilover style:
Extd: 19.125"
Col: 14.625"
Dia: 2.0"
Spring Rate: 600 lbs
Inside Dia: 2.5"
Spring Length: 12"
They told me to bump up the spring rate to 650lbs or 700lbs. I asked though, which is it? He said since its a 4.0L, the 700lbs would be best. Then you can back off the spanner/adj nut and have no preload on the spring. I think I'm going to get fox shocks. The 2.0 coilover remote reservoirs 6.5" with 14" Eiback 700lbs springs. I hope it rides better than now, I swear I have no suspension on the front now...lol
Just thought this might help all you out there looking for this info.
Old 02-03-2007
gumby's Avatar
welcome to RF and thanks for the info! i know a couple guys on ORR are lookin for it too.
got any pics of your truck? you have the same setup i will have in a couple more weeks. ive got the 1" BL on and will be installin the RCD very soon.
Old 02-13-2007
l2en's Avatar
I'm looking to mount 35"s on the truck in the next three weeks. I'm in desperate need of new coilovers. Mine are rusty as hell, stiffer than they def should be, and the bushings are shot!
Got any links to the fox or eibach products?
Old 02-13-2007
gumby's Avatar
unfortunatley travis, this guy hasnt been back since this(his one and only) post.
here is a post from ORR that has some info on the FOX shocks.
http://www.offroadrangers.com/forum/...&postcount=227
generic disclaimer: i CANNOT vouch for the correctness of the guys info on ORR. jus tryin to get you as much info as possible, do your own research!
Old 02-13-2007
l2en's Avatar
Originally Posted by gumby
generic disclaimer: i CANNOT vouch for the correctness of this guys info on ORR. jus tryin to get you as much info as possible, do your own research!
lol, thanks gumby!
Old 02-13-2007
He's made posts since that post, but hasn't said anything about the information in that link.
Old 02-13-2007
gumby's Avatar
sorry, talkin about two different "this guy"s.
the guy who authored this post(on RF) has not been back. ill edit to attemt to clarify...
Old 02-13-2007
l2en's Avatar
I'm having a hell of a time locating 14" 700lb eibach springs
Any ideas/links??
Old 02-13-2007
I follow ya now. You know, when Red posted the info about the fox coils I tried searching on-line for that part number with no luck. I was kind of baffled by that.
Old 02-13-2007
Any ideas/links??
I located the springs on summit. I'll see if I can locate them again and post the link up.
Old 02-13-2007
12" 2.5" inside dia. 700lbs.
http://store.summitracing.com/partde...5&autoview=sku
But we want 14"
14" long 2.5" inside dia. 650lbs
Old 02-13-2007
l2en's Avatar
I searched the Fox part number and came up with about 15 dif dealers. Every single one of them wants $235/piece for the shock. This one has free shipping though =]
Fox Shock
Old 02-13-2007
now where in the hell is this 14" 700lbs spring!
Old 02-13-2007
l2en's Avatar
Old 02-13-2007
logan03CO's Avatar
Yeah I cannot find the spring either! I only see a 12" in 700lbs...or 14" in 600lbs (I think)
Old 02-13-2007
the site you listed for the fox shock also only lists a 14" 650lbs coilover spring.
If memory serves me right the RCD-bilstein COs are 600lbs.
Sticky please? Maybe?
Old 02-13-2007
logan03CO's Avatar
Yep that's I heard too....
Old 02-13-2007
hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm
pricey, but hmmmmmmmmmmmmmmmmmmmmm
Donahoe Racing F-150 coilover 2.5" shock diameter
I wonder if they'd work!??? There's no other dimensions?
Old 02-13-2007
l2en's Avatar
*Lets cat out of the bag*
I wanna buy the new shocks and coils after I work out the deal for a set of deavers, buy new rear shocks, modify my front bump stops, and I picked up a POR-15 starter kit to recoat the kit components.
I kinda wanted to buy the coils now since they're the cheapest part of the pair. I'm gonna be strapped after the rims, tires, rear shocks, and deavers.
Old 02-13-2007
l2en's Avatar
Yeah right....I don't care if they would or not. $1200 can get me alot more than a pair of coilovers!
Old 02-13-2007
I hear ya. With my tax return I'll be able to afford the 15X8 Teflon Mojaves, just not sure if I want to get them yet. I found them on ebay for a 4-set for $525 I believe, free shipping.
The new tires will come later this year, but that's also why I haven't gotten the new rims yet. Not sure if I want 15x8 or 15x10s for 35x12.50x15 BFG MTs. What I do know is once my tax return gets here $455 of it goes to Scott for his 4.88 front diff and rear diff 4.88s. Already got the deavers and I want limit straps for front and bilstein 7100s for rear. I also need to kidnap Bob (rwenzing)
Old 02-13-2007
gumby's Avatar
Extd: 19.125"
Col: 14.625"
Dia: 2.0"
Inside Dia: 2.5"
Spring Length: 12"
Old 02-13-2007
l2en's Avatar
Lol!
Old 02-13-2007
hey gumby, call me pokey!
BTW, I hate you
Old 02-13-2007
gumby's Avatar
BTW, I hate you
get in line buddy, lol
Quick Reply: Rcd New Coilover Shocks
