2wd Trailmaster Discussion
Old 02-17-2007
jrpro130's Avatar
So, we were talking about stacking the trailmaster lift on the drop spindles for the front on a 2wd edge (torsion bar) truck.
I think i may be the test dummy...so that will equal how many inches of lift is the question?
Cost?
Will it work?
Will it put extended wear on the tie rods (they are stretched out already...)?
Is it safe?
Superlift? Same thing right?
I'll be the test dummy, if anyone stumbles across a cheap trailmaster...lmk
Old 02-17-2007
NO NO NO NO N ON O NO NO NON ON ON ONO NO N ON ONON ON ON have you seen pics of how this lift works hack no... NO NO NO
Old 02-17-2007
jrpro130's Avatar
Ok, someone was talking about it in another thread. Why wouldn't it work...it's just drop bracketry, and it uses your stock spindles...
Please explain.
Old 02-17-2007
gumby's Avatar
its not a hard core wheelers kit, but depends on how you use your truck. it works similar to the SL kit, except they extend the spindle up with a bracket instead of buildin a completely new unit. they have brackets to take care of the tie rod issue.
should be roughly 7.5" lift
i know where you can get one $600 plus shipping if its still around, and she will ship it.
Old 02-18-2007
jrpro130's Avatar
Hmmm...its something to think about.
How safe would it be though? I mean 600 for 4" more lift would be good IMO. I just don't know if thats pushing it? I mean I could clear 38's most likely with that setup...maybe I'd stick with 37's and some gap though...I dunno
Old 02-18-2007
01Blueedge's Avatar
i was thinking about the same thing but i am wondering if it would work too
Old 02-18-2007
jrpro130's Avatar
I'd do it in a heartbeat...I can use all the extra clearance I can get!
I am not wheeling her that hard anymore so I don't mind the ball joint spacers either.
I just want the extra lift.
Old 02-18-2007
gumby's Avatar
the only issue i see is that the attachement to the top of the spindle is designed for the shape of the stock spindle. if the aftermarket spindle has a different shape, you may be in for some slight mods to get it all attached securely. im pagin scottyG, he found some good pics of the attachement point at the spindle, please hold.....
Old 02-18-2007
jrpro130's Avatar
10-4...
I don't mind modding it, I had to drill my spindle out a little for the bj to fit right anyway...just a 1/16th though
Old 02-18-2007
the trailmaster uses almost the exact same setup as the superlift except for a balljoint spacer. Which allows you to reuse your stock spindles (OR if your luckly, you can use lifting spindles on a 2wd and have a double suspension Lift)
Now, i know people say dont use it, But if you have a street queen with little to no offroading, this is a perfect setup. However, buying one new, its the same price as a superlift, and for a 4x4, its not worth the cost
Now, the balljoint spacer is a square piece, that has a hole ontop that your balljoint slids into, and a stud on the bottom that slids onto your spindle. And also has ubolts that clamp around the spindle to hold it together better.... Now the down side of this, it has round ubolts, so if you are using an aftermarket fabtech spindle that is square uptop, you will have to find different spindles, or square ubolts.
Also, haveing a 4inch lift ontop of a 3inch spindle will defienetly require some looking at the brake lines, I doubt theres enough slack for 7inches of suspension. But its an easy fix with some custom lines (just not super cheap)
Now for some pics
Here is a great pic of the balljoint spacers attached to the factory spindle
Old 02-18-2007
jrpro130's Avatar
Wow, this looks really do-able.
What about hte tie rods? Mine look pretty stretched out already...
And brake lines, all I need is some help finding thhe product number from summit
Old 02-18-2007
the tie rods get relocated lower, same as the lower arms and tbars
not a pretty pic, but it shows the stock and new parts
Old 02-18-2007
ya you still have to drop your crossmember like a superlift/rcd
Old 02-18-2007
gumby's Avatar
definatley do-able, IMO.
im glad you kept track of all the pics scott. i threw em all away after i sent em to you
Old 02-18-2007
this MIGHT explain the tierods better
Old 02-18-2007
wow that looks interesting
Old 02-18-2007
jrpro130's Avatar
I'm kinda confused on the tie rods? It drops the whole rack down? or is it like an extension?
Old 02-18-2007
gumby's Avatar
thats a ood pic there. shows how everything is mounted and how it works together. so you can see how it should still work, even with a lift spindle.
Old 02-18-2007
gumby's Avatar
it is a drop bracket. the rack stays in the stock position.
Old 02-18-2007
l2en's Avatar
lol, that's what i was thinking. haha
Old 02-18-2007
jrpro130's Avatar
hmmmm...if I can get a decent used kit for a decent price, I'll try it.
I just don't want to spend 1k on it, b/c that would be how much my SAS w/ a little d30 would cost ME...
Old 02-18-2007
heres it in paint, to show the tie rod relocation
Old 02-18-2007
jrpro130's Avatar
Ahhh, I see, so that whole assembly moves so the tie rod can move...I get it!!!
Old 02-18-2007
rolla_guy72's Avatar
I was initially going to give you a negatory on that one, but darn it, it looks like it will fit... looks interesting...
How are those Endlinks? I know there were some Superlift guy's having problems with the endlinks and ended up chaning them to RCD endlinks (??)
Old 03-30-2008
not for me.
Quick Reply: 2wd Trailmaster Discussion
