How-To: Remove Rear Jump Seats and Seatbelts
Old May 9, 2007
Ranger-James's Avatar
Tools needed:
-A full Socket set (with T-40 and T-50 bits)
-Needle nose plyers
-Black Duct Tape
I wanted to remove my rear jumper seats on my ext cab 04 ext ranger.
Start by removing the plastic molding. First remove the plug by pulling it out slightly with your nails, then use the needle nose plyers. Pull out straight to reduce chance of breaking the part.
Now unbolt the Hindging bolts using a T-40 (top red circle)
Remove the seat unit
Next Unbolt the 2 bolts that require a T-50 bit. If you have the right tools you can skip unbolting the bolt shown with a red circle and just unbold the bold shown with a red square.
Now using a metric normal socket unbolt the remaining bolts.
Now you are done with the seat!
Now you could call it quits or you could remove the seat belt reciever. After doing it, I dont know if i would do it again...
Here are the steps I took to remove the seat belt reciever...
Unbolt the seatbelt from the door using tools listed above.
Now remove the trim around where the belt goes into the door. It has a cut in the back to make for easy removeal. I used my finger nails again to pry it out.
Next Carefuly remove the plastic sideing (shown here in grey) This will take some force. Try to remove it pulling out in a striaght manner.
I Unbolded the seatbelt reciever (sorry i forgot to take a pic of it) and now i had I wanted to fill the hole so that I dont loss stuff in the new hole. I used the handy mans secret weapon. Yes, DuctTAPE! I used black ducttape applying to the back of the panel. Once the hole is coverd up, Pop back in the panel and you are done!
Old May 10, 2007
pastfinder's Avatar
You don't have to unbolt the seat from the bracket to remove them. You can just unbolt the bracket and remove the seats that way.
Old Oct 9, 2017
mvg's Avatar
mvg
Better to remove seats in one piece
As suggested above, just remove the four 13mm and one T50 bolt in each bracket, and remove the seats intact. Saves a lot of work.
Old Jan 5, 2021
mD1996's Avatar
thanks this helped alot
offroadohio
Project Logs
30
Sep 25, 2011 05:21 PM
trextegra
Audio & Video Tech
42
Apr 4, 2011 05:11 PM
drppdyllwrngr
Jan 29, 2011 07:37 PM
silverfox
Sep 15, 2010 06:00 PM
GrafixGuy
May 17, 2009 06:43 PM
