My new home made intake
Old Jul 24, 2007
vindex1963's Avatar
I bought 3" aluminum tubing and connectors, grommets and vacuum line connectors. The crank case vent and the power brake "vent" are all factory. I hooked up to the factory air box because it's a true cold air intake. I was going to do a write up on how to do this but if you have any mechanical abilities it's easy to do. It took me a little under 2 hours and that's because I'm **** about fit and making the cuts correct. I do a lot of off roading so the connections are air tight. The vacuum line connectors that fit into the 3" aluminum tube are just big enough to fit the vacuum line adaptor so no leaks there.
If I need to go back to the factory set up it's a case of 2 hose clamps and pulling the vacuum line adaptors out. Simple!
Total price $109.36
Together with my air box mod it should flow all the air it could
ever need.
http://www.freewebs.com/arizonarider...madeintake.htm
1 18"X3" aluminum tube
1 45*X3" angled aluminum tube
2 3" into 3" adaptors
1 3" into 2 1/2 adaptor
5 3" stainless hose clamps
1 21/2" hose clamp
Old Jul 24, 2007
camodown's Avatar
Lost in Nowhere
look good, nice job
Old Jul 24, 2007
graniteguy's Avatar
it looks nice!
Old Jul 24, 2007
redranger04g's Avatar
nice job, doesnt look like its home made at all
Old Jul 24, 2007
vindex1963's Avatar
Thanks, not home made looking is what we all want. It should work AT LEAST as good as the factory unit.
Old Jul 24, 2007
vindex1963's Avatar
I had a question about the intake rubbing the fan blade or the alternator pulley.
Here are some photos to show you.
The fan is an easy 1 1/2 away.
The alternator pulley is about an inch.
Miles of clearance.
Old Jul 24, 2007
0sixsport's Avatar
Looks awesome man!
Old Jul 24, 2007
nice job
Old Jul 24, 2007
vindex1963's Avatar
Thanks, I didn't think it would turn out as good as it did.
I put it on my web page.
http://www.freewebs.com/arizonarider...ldairintak.htm
Old Jul 24, 2007
wow that looks really good... nice job
Old Jul 24, 2007
vindex1963's Avatar
Thanks, I wish the pictures looked like it does in person.
Old Jul 24, 2007
Eddy04's Avatar
Icon14
Looks good! ...GREAT JOB. Any increase in performance, sound?
Old Jul 24, 2007
0sixsport's Avatar
In his write up he said he attained a notceable increase in power at and above 3000 rpms.
Old Jul 24, 2007
LowMaz's Avatar
nice write up man... i bought my cone filter on ebay for like 10 bux shipped... i like ur enclosed box much better tho!
Old Jul 24, 2007
IR0NS1N's Avatar
Problem is MOST power out of a basic "K&N CAI" is from the cone filter and the overall area in which air is sucked in. Im sorry I dont know the correct term for this. The tube from the air housing to the TB really isnt where the increase comes from. So if anyone out there thinks just adding a tube will give notticeable power, I doubt most people will be satisfied.
Old Jul 24, 2007
Lord Of War's Avatar
I always thought that the least amount of resistance meant the more power?
Old Jul 24, 2007
LowMaz's Avatar
correct, doing the tube DOES help some but not a ton
Old Jul 24, 2007
bryanjints's Avatar
well I am sure for the small added performance and killer look it is well worth it. I love it I want one.
Old Jul 24, 2007
vindex1963's Avatar
All on it's own probably some help like you said but I have done other mods that seem to be working together quite well. There is a noticeable change at and over 3000 rpm. Opening up the air box by removing the snorkel by itself isn't much but adding the tube replacement now they both are working together to have an effect. At 3000 it's more like a two stroke hitting it's power band. Not extreme like a two stroke but it gives you an idea of what I'm talking about and it pulls strong up to 5000 rpm, something it didn't do before. I need that for passing while I'm driving through the mountains.
Old Jul 24, 2007
LowMaz's Avatar
be serious, its so u can smoke all the civics out there!
Old Jul 24, 2007
vindex1963's Avatar
Well.................
Old Jul 25, 2007
vindex1963's Avatar
Thanks for the compliments.
Old Jul 25, 2007
Originally Posted by D.
Outstanding work! Looks like a pre-fabbed or store bought entity.
This write-up needs a sticky and to be added to the how-to's section
x2. Good work.
Old Jul 25, 2007
GrafixGuy's Avatar
looks nice!
