center hub bore on rear drums
Old Aug 22, 2007
gumby's Avatar
i know the hub bore changed on 10" drums at some point as i had a set of 94 10" drums that would not fit my 03 rear.
what i need to know is what year the change happened, AND if the 9" drums have the same change.
i need 9" drums with the larger hub bore.
Old Aug 23, 2007
gumby's Avatar
RECRUITS read here:
i need measurments of the center hub of 9" drum rears. if you have a 9" drum rear and meet the other qualifications in my GD thread , please continue.
  • remove a rear wheel from your ranger
  • measure the diameter of the hub protruding from the center of the drum
  • report back in this thread with the year of your truck and the diameter of the hub
i am workin on a 5lug swap for a slightly off beat axle combo. i am hopin ranger drums will fit my application w/o additional machining. i am certain they will fit other than the center bore, jus lookin for some confirmation on hard numbers before i walk into the parts store and buy a pair.
Old Aug 23, 2007
gumby's Avatar
ok, i went year by year on autozones website.
p/n 8952 - 9" rear drum up thru 97
p/n 80036 - 9" rear drum 98+
center hub looks bigger in the pics of the 80036. can anyone measure a 98+ truck with 9" rear brakes for me??
Old Aug 23, 2007
gumby's Avatar
Originally Posted by 04 EDGE
98+ has a larger center hole. should work
should work on what? you dont know what axles i am tryin to use or what the hub size is on them
FWIW, i am tryin to use 94-98 sn95 mustang axles (~2.75" hub)
Old Aug 24, 2007
well you didn't post that so i am just as dumb as you.
and if your gonna use a mustang axle why not get one with rear disk brakes? and why downgrade from 10 inch drums to 9?
my head hurts now.
cause its not going on a mustang, its an older thunderbird
and 10inch brakes would be disproportional with the 10inch brakes up front
Old Aug 24, 2007
gumby's Avatar
  1. i didnt originally specify what axles i was using because i didnt want to muddle the situation with questions about what im building. i only needed measurements, then we can talk about it, if it works
  2. i said im using mustang axles, as in shafts, not a complete rear axle
  3. its not a downgrade when the car im adapting currently uses 9" drums
  4. im not using rear discs because the application and intended use dont necessitate the extra work or money involved to properly set up the master cylinder and prop valve for a balanced four wheel disc system
thanks.
anybody got a measuring tape and 5 extra minutes? id measure it myself if i had access to a truck to measure, i know someone here has a 98+ with 9" drums
Old Aug 24, 2007
CougarSE's Avatar
Scott!!!
Been talking with Gumby on this for some time now. Its a compilation of parts to make a very easy 5 lug conversion.
Old Aug 25, 2007
Originally Posted by CougarSE
Scott!!!
hey, i didnt realize you were on here, and heck looks like its been a year
I offered gumby a complete 92 drum axle, but he didnt want the 10inch brakes
pericao209
Nov 22, 2014 07:12 PM
rangerrunner11
Jan 18, 2012 11:28 PM
Nitrix
Aug 6, 2010 04:22 PM
04rangerxlt
Jan 23, 2007 10:56 PM
04edge
Mar 10, 2006 06:57 PM
