a1 electric alarm and power doors..help
A1 sells several different models of alarm, keyless entry, and door lock systems. Without seeing the installation diagram for your unit it would be hard to give any recommendations...
If your talking about the starter kill feature you'd normally install a new relay inline with the vehicles starter relay control wire coming from the ignition switch under the dash. There are several ways this relay can be wired depending on the alarm systems input/output. Same goes for the horn control whether or not its a ground or power output at the alarm module.
Can you post a copy of the installation instructions?
04blackedge
07-22-2010 03:23 PM
btm757
12-08-2009 07:32 AM
winks
10-10-2007 08:08 AM
