3.0, 4.0 OHV, 4.0 SOHC Fuel Pressure.
Old Feb 12, 2008
redranger4.0's Avatar
All these threads about fuel cells have been poping up. Ive been getting contrasting info about which engine uses what for fuel pressure.
TRS lists the 3.0 to need 30-40psi.
3.0 specs
TRS also lists the 4.0 OHV to be 30-40psi, while the SOHC is listed 64-75psi.
4.0 OHV and SOHC specs
So who wants to join in and clear this up if these numbers are correct or not.
Old Feb 12, 2008
Rockledge's Avatar
The 30-40 psi specs are for Fords that use a conventional "return" fuel system.
1998+ Rangers use a mechanical "returnless" fuel system regardless of the engine. Mechanical returnless fuel systems have the following characteristics:
(1) there is no return line running back to the fuel tank from the fuel rail;
(2) the fuel pressure regulator is now in the fuel tank with the pump, not on the fuel rail;
(3) theyare designed to operate at higher fuel pressure (64 +/-8psi for gasoline engines, 55psi +/-8 ps for FFV);
Old Feb 20, 2008
levelIIrdneck's Avatar
the 4.0L SOHC engine has a pressure regulator on the drivers side fuel rail on the very back. i found it on mine in class
Old Feb 20, 2008
Rockledge's Avatar
What you are describing is the fuel pulse damper, which the Ford Manual describes as follows:
Located on the fuel rail is a pulse damper. The pulse damper reduces fuel system noise caused by the pulsing of the fuel injectors. The vacuum port located on the damper is connected to manifold vacuum to avoid fuel spillage in the event the pulse damper diaphragm were to rupture (the pulse damper should not be confused with a fuel pressure regulator).
Old Jun 2, 2021
ThuyTrang's Avatar
Thanks, Rockledge, for your clarification, it's important to note the difference. Do you happen to know on a 2007 ranger 4.0 if this also has the fuel dampener on the drivers side rail towards the back? I am having fuel pressure attaining 55ish PSI and then dropping off to 30ish and slowly bleeding down from there. No apparent leaks and replaced fuel pump.
Thanks, David
Old Jun 2, 2021
RonD's Avatar
Fuel damper is just there to stop pressure waves from building up in the fuel rail, pressure waves form when injectors open and close, the damper at the end of the rail/tube absorbs the waves so they don't reflect back into the tube, its just a rubber diaphragm, the vacuum hose is for safety, if diaphragm should leak it would drip on HOT exhaust, a BAD thing, lol, vacuum line would suck any leaking fuel into the intake and cause Rich codes
Fuel pump assembly, the whole unit, has the fuel pressure regulator(FPR) as part of the assembly
So did you change the whole assembly or just the pump?
And with key off fuel pressure may bleed off, but not while engine is running, so please clarify when pressure is dropping
Old Jun 2, 2021
ThuyTrang's Avatar
Hey Ron,
Thanks for jumping in on this. This goes back a ways, and you and I exchanged a number of messages and I'm sticking with your 50/50 test which led me to establish low fuel pressure @ rail (0-20psi). We have most recently replaced fuel filter and pump/ assembly (the entire unit.. pulling the bed BTW is far easier than dropping the tank IMO), and we now get 55+PSI @ rail but then it quickly drops off to 30 and then slowly bleeds down (engine isn't running so goes down after cranking). Also while there drained and cleaned tank (nasty, gas turned orange/ yellow) and put new gas in. So, we've made progress. But still not there (running) yet. I am as interested in checking the vacuum line on the dampener JIC.
To review briefly:
- 07 4.0 Ranger purchased as 'salvage'
- Ran initially though briefly but had loud knocking in "upper end"
- spark was orange so we replaced coil, plugs and wires; blue spark now
- compression 120+/- on all cylinders (not optimum but should suffice)
- adding starting fluid to carb seems to get it closer to firing and on occasion has started briefly 'almost going' (after which died) but not consistently
Since then I've run down the various lists some appropriate and necessary, some not.
- verified PATS not activated
- checked inertia switch (though I am almost at the point of bypassing JIC)
- swapped corresponding relays/ checked fuses
- disconnected MAFS
Probably other things I've checked (mostly based on your input) but not resolved yet, most appreciative of your thoughts, insights, etc.
David
Old Jun 2, 2021
RonD's Avatar
Knocking at top end and compression of 120psi reads like valves are out of time
Was average compression in all 6 cylinders 120psi?
You need to test all 6 with no spark plugs in the engine, and battery voltage at or above 12.4volts, so you get good crank speed
4.0l SOHC runs 9.7:1 compression ratio so expected static compression(cold engine compression test) would be 175psi
If compression is 120psi then you may be chasing your tail with spark and fuel issues
Ether(quick start) might get it to fire, but compression that low would be marginal for gasoline and carb cleaner
Spark can't ignite a liquid fuel, yes the movie guys take liberties with that fact, lol, spark can only ignite fuel vapors
The point of higher compression is to heat up and vaporize part of the fuel so a spark can ignite it, when that happens the ignition will quickly vaporize and ignite the remaining fuel in the cylinder
Without the initial ignition point then no start
Ether becomes a vapor at a lower temp than most fuels, which is why its used to start cold engines, gasoline or diesel engines
Old Jun 2, 2021
ThuyTrang's Avatar
Thanks Ron. When I tested compression it was one cylinder at a time and I replaced each plug after doing it so never with all 6 out. Battery is new and has been on tender so although I didn't verify voltage (I can) I suspect it was sufficient but will if you feel it's necessary.
But given what you said, given low pressure and other items attended to/ checked, is it your opinion that I should pursue troubleshooting valve timing?
David
Old Jun 2, 2021
RonD's Avatar
Test all 6 cylinders again, spark plugs out
write it all down
Add up the 4 cylinders that are in the middle, don't use the lowest or the highest number
Divide total by 4, and that will be the average compression number
If its under 150psi then valve timing is most likely off
If one bank/side of the engine are all lower than the other side then that one cam in that side is out of time
Old Jun 3, 2021
ThuyTrang's Avatar
Thanks again Ron. They were all within 5-10#s of one another but I will rerun the test under the conditions you've indicated. If I understand you correctly, if they are in fact all ~120 and given the other information, I should then look into valve adjustment next as a means of getting the engine running, correct?
David
Old Jun 3, 2021
RonD's Avatar
There are no valve adjustments, just valve to crank timing via the timing chains
jdbs3
Aug 2, 2018 12:47 PM
Apexkeeper
Jun 10, 2018 08:13 PM
mixterl1
Feb 20, 2015 07:45 PM
StxDangerRanger
Feb 5, 2013 03:34 PM
Rooks
Dec 28, 2011 11:52 AM
