front driveshaft disconnect
Old Mar 12, 2008
elementsenjoi's Avatar
In the past 8,000 miles i have been through 2 driveshafts (stupid CV joint). since i don't really want to keep replacing them and i also don't want to buy the $400 superlift d-shaft, i am going to build my own. i haven't decided if it is going to be a double cardan style or just a single u joint on each side of the shaft. i will also be attempting to fab a drive shaft disconnect into the shaft instead of trying to put in manual hubs. the disconnect will probably be closer to the front of the d-shaft so that the shaft wont move when unlocked. i have all of the parts needed for the disconnect and two stock shafts laying around. it might be a slow process but it is going to happen. here are some pics:
i will try to keep taking pics throughout.
Old Mar 12, 2008
RazorsEDGE's Avatar
Pretty sweet plan you got there. I would definitely go for a double cardon on the transfer case end of the shaft.
Old Mar 12, 2008
yeah, my dad's idea. you really think i'll need the double cardan, even though it will only turn if i have the shaft locked in?
Old Mar 12, 2008
Yes, because generally the u-joint angles AREN'T equal on the front the way the are in the rear. Without a double-cardan you'll have different velocities trying to happen at each end during the rotation and that'll be a strain on something -- it's not just the "vibration" issue.
When the angles of the two joints aren't the same that's when you need a double-cardan.
Old Mar 12, 2008
RazorsEDGE's Avatar
Yup thats right. If you take a close look at the t-case you'll notice it actually points up a little bit. The angle will be too steep if you don't use the double cardan. If you're gonna make a custom shaft anyways don't risk not using the double cardan.
Old Mar 12, 2008
ok, thanks for the info.
wellcom2knoxvile
OLD - Engine & Drivetrain
Aug 23, 2010 07:17 AM
Dalmatian90
May 24, 2009 01:47 PM
Goodysgotacuda
Apr 4, 2009 08:55 PM
034x4
36
May 25, 2005 12:20 PM
rocklobster
Jan 31, 2005 09:19 AM
