2wd Spindle Lift
Old Jun 10, 2008
CBFranger's Avatar
2wd Spindle Lift
Is there a reason that there are no lift spindles for 2wd's with torsion bars?
I refuse to sacrafice ride quality and potentially making my ball joints suffer by cranking my torsion bars. Thus, if want it lfited I only have coil spring conversion and coilover kit (complete overhaul of the front suspension). Neither is cheap or something I feel like undertaking on my own.
I am thinking about going to a fabrication shop with some junkyard spindles (for reference) and having them construct me custom lift spindles from scratch. Is this a real possibility?
I am going to be changing my ball joints with in a year anyway and I have no issue with changing my own spindles and repacking a couple bearings agian (I say agian because I had to replace my rotors 2 years ago).
Old Jun 10, 2008
Uh there are spindle lifts for torsion bar 2wds. Search for it. Heres a example link:
http://www.1motormart.com/parts/1/20...Ranger+Spindle
Old Jun 10, 2008
CBFranger's Avatar
Edit: Never mind.
I have a '00. Fabtech spindles start in '01.
Old Jun 10, 2008
Nope there is, thats like the one of two ways to lift out trucks lol. Fabtech makes a good one and Doestch makes a budget one.
Old Jun 10, 2008
CBFranger's Avatar
http://www.fabtechmotorsports.com/ap...-05ranger.html
Doetsch doesnt specify wether the spindles are for coils or torsions.
Old Jun 10, 2008
Its on that Fabtech site, look at the very bottom. Theres also something about it in the middle.
Old Jun 10, 2008
Prerunner-Ranger's Avatar
Level I Supporter
I wouldn't go doestech.... they tend to break.
Old Jun 10, 2008
If you jump the truck yes. Thats the only cases I've seen of them breaking, is people that have jumped the front end. Even stock parts won't hold up to jumping the truck. Go ask My05Edge how he knows lol
Old Jun 10, 2008
CBFranger's Avatar
Still not seeing it. 2001 Ranger Edge, yes. 2000 Ranger 2wd with Torsion suspension, no.
I'm wondering if 2001 edge is the same as my 2000 Mazda B3000 TL.
Old Jun 10, 2008
RazorsEDGE's Avatar
Is your truck a trailhead?
The trailhead suspension is identical to the 01-up 2wd edge.
Old Jun 10, 2008
Uh I don't think there are any 00 with torsion bars that aren't 4x4. Do you have a pic? Are you the guy with the Troy Lee Mazda? If its the torsion bar suspension then those spindles will work.
Old Jun 10, 2008
RazorsEDGE's Avatar
You have the Mazda equivalent to the Trailhead. So yes, the 01-up Edge spindles will fit.
Old Jun 10, 2008
CBFranger's Avatar
Yeah, I have the Mazda B3000 Troy Lee edition.
No wonder I couldnt find any 2000 Ranger Torsion Suspension products.
RF.com FTMFW!
Now I know what to look for.
Old Jun 10, 2008
nbro3232's Avatar
you may also have different size brakes, someone correct me if I'm wrong
Old Jun 10, 2008
i think they were all the same up to 03
Old Jun 11, 2008
CBFranger's Avatar
I'm pretty sure I have 11.25" brakes.
I'm excited now. I am debating between lift or motorcycle....
Old Jun 11, 2008
Step Over the Edge's Avatar
Both! Buy your lift and get a loan for the bike. What's the problem?
Old Jun 11, 2008
CBFranger's Avatar
The part about college and the inability to keep a full time job year round.
Old Jun 11, 2008
S10Killer's Avatar
for the t bar fabtech kit the last 4 numbers are 300-7 not the 200-7 if you want the spindel kit for it
Old Jun 11, 2008
Level I Supporter
No reason to jump the truck with spindles lol.
That's just outright dumb.
I went over a speed bump and my snout broke off my doestech spindle, I wasn't jumping anything.
I tried calling suspensionmax.com and they have the worst customer service ive ever seen.
Old Jun 11, 2008
CBFranger's Avatar
Sweet. Thanks for the heads up.
What is ya'll opinion on doing this by yourself?
I've already had to change the rotors on the truck so dealing with the bearings and all isnt a biggie.
I've done a lot of easy-moderate engine work. Down to intake manifold swaps, cam swaps, throttle body swaps, etc...
I've rebuilt a briggs 8hp go-kart motor after doing all of the performance mods to it (advanced timing, smaller combustion chamber for higher compression, removing any corners in the combustion chamber so hot spots cant form, etc...)
I've never messed with suspension much, how hard would this be for me? Just to have the local suspension and tire shop replace my ball joints and do an alignment would cost me $450. For that money I can do it myself and just have them align it for $50 and it'd be like $200 off the cost of the lift spindles.
Old Jun 11, 2008
S10Killer's Avatar
its easy ball joints on the ranger are cake, so putting in a spindel is too i did my spindle lift in 1 hour for real .
Old Jun 11, 2008
CBFranger's Avatar
Any other info I should know before I start the serious thinking and finance arangements?
Old Jun 15, 2008
country346's Avatar
Its super easy , Honestly from some of the posts you have posted I think you have enough mechanical knowledge to do it yourself . ITs farily simple when you really think of it I honestly think I could pull it off in under 1.30 mins including tool prep & clean up .
Old Jun 15, 2008
00Ranger's Avatar
1.3 mins thats amazing hehe . . . .im assuming thats an hour and 30 mins.
