Single Cab Sub/ Amp Setups!
Old Jun 18, 2008
MEC454's Avatar
LOOKING FOR IDEAS ON MY SETUP. POST UP!!
Old Jun 19, 2008
redrebel66's Avatar
Old Jun 19, 2008
MEC454's Avatar
nice! are those 12''s? did u cut the plastic paneling and do you still use the rear speakers?
Old Jun 19, 2008
redrebel66's Avatar
Those are 10's and all the paneling it still there. No I dont use the rear speakers. No point the subs would just cancel them out.
Old Jun 19, 2008
MEC454's Avatar
sealed? rms?
Old Jun 20, 2008
CBFranger's Avatar
Actually, there's no point in rear speakers at all if you want true stereo sound.
Old Jun 20, 2008
redrebel66's Avatar
Yeah its sealed.
Old Jun 21, 2008
MEC454's Avatar
i wanna put 2 10'' kicker l7s. if they don't fit gonna put 2 8'' l7s.
or should i go with 2 12'' cvts? still debating....
Old Jun 21, 2008
oldman_d's Avatar
How much power are you sending to each?
Old Jun 21, 2008
XeRo's Avatar
I wish I could put two of my type X's in my single cab.
Old Jun 21, 2008
redrebel66's Avatar
Its a phoenix gold octane 1500.1 bridged to 2 ohms
Old Jun 22, 2008
timpat92855's Avatar
l7 10s in a single cab wont fit without a cut throw. MY buddies 91 s10 single cab has 3 l7 12s in it but the box is in the bed and has a whole cut in the cab. He had 1 l7 8 before we cut it and it did ok. BUT all solobarics need airspace, without it you will do nothing but burn voice coils, like he does all the time
Old Jun 24, 2008
MEC454's Avatar
2 8''l7s or a 10'' cvx? hmmmmmm......
Old Jun 24, 2008
MEC454's Avatar
whats cut throw?
Old Jun 24, 2008
Cut the cab and the bed...have a metal box in the bed and slide a wooden box in with the subs behind your seat...very hard to do the first time since your cutting a big rectangle whole in your trucks cab...stick with one l7 8 and get someone to build u a vented box for it and get a 400x1 amp...people will think you have 2 12s i promise...
Old Jun 24, 2008
Marcaronio's Avatar
https://www.ranger-forums.com/forum2...ad.php?t=36258
Old Jun 25, 2008
805cali's Avatar
here's an idea
ok so im not trying to put u down but ur dreaming if you think you can fit 2 l'7s in a single cab. i have two l7's 15" subs in my 2001 ford ranger and my whole back seats are gone,,, my suggestion is that you pull this bad *** trick out... check it out you take the soda holders out in the midlle of your truck and try and make as much space as possible and then you custom build a box to fit in there as deep as you want it then you go buy yourself the sub and amp,,, then you proceed by securing the amp behing the seats so its hard to see and more safe to have then under the seats and run the sub wire to the sub thats sitting in the middle of you and your passenger... i dont kno if you get it or if it sounds crazy but i've seen it done and you would be amazed along with the other people thinking that your truck is all pimped out... also make sure just to buY a sick *** sub and not to go over 12'' CAUSE THEN IT MIGHT NOT FIT..
Old Jun 25, 2008
He might fit above 10s but does not have enough room for the air space of a solobaric...people go for the biggest sub...look at the air space specs on a l7 15...then go to one of the sub box calcu. to figure out how big the box would have to be then see if u can fit it in a single cab... and have you ever seen a company make a box for solobarics for a single cab, cant say i have...nough said
Old Jun 25, 2008
MEC454's Avatar
clean mf install. love it man
Old Jun 25, 2008
MEC454's Avatar
so whats your guys opinion......2 8'' l7s, single 10'' l7 or 10'' cvx
http://reaudio.com/speaker_box/LPort_Box_Calc.html
used that as my calculator. any of those speakers fit with adequate air space. im thinking 2 8s. less mounting depth and i can use 2. what ya think?
Old Jul 14, 2008
da lone ranger's Avatar
i guarentee you could fit 2 10 cvx's. some time in the near future im going to put in 2 audiobahn 12's behind my seat. my 1 10 cvx is loud enough but i know the 12s are going to pound loud
Old Jul 15, 2008
MEC454's Avatar
3 8" L7s or 2 10" CVXs??????????????????????
Old Jul 15, 2008
yellerEDGEchick's Avatar
1 10" and it pounds like crazy. I had to turn the amp almost all the way down.
Old Jul 16, 2008
akjay907's Avatar
what are you talking about???
KICKER makes a prefab box for L7s and L5s for a single cab truck, and you can get it with the sub in it!!!
i fit 2 10" L5s in a ranger single cab. almost 3cf^@33hz
Old Jul 16, 2008
MEC454's Avatar
pics ftw please.
