EGR and DPFE
Old Dec 12, 2008
marcua56's Avatar
EGR and DPFE
I having a check engine light coming on in my 2000 ranger xlt. When I used the scanner at autozone It read that it was a problem with the EGR. So I replaced the EGR valve but the light was still on Ao i took it to my local mechanic to have it looked at and he said it was a problem with the DPFE. To be honest I have no idea what that is or how to fix it. Any advice or pics would be GREAT.
Thanks
Tony
Old Dec 12, 2008
bwester04's Avatar
Delta Pressure Feedback EGR Sensor (DPFE) looks like this^
I never had to replace mine, but i've heard you can clean it and see if that helps. Somebody that has actually had problems with theirs will chime in soon.
Old Dec 12, 2008
Alie's Avatar
This is the easiest fix ever...if I can do it, so can you. Just two bolts- make sure there are no cracks in the hoses while ur replacing it.
I stole this from another thread.
Old Dec 12, 2008
Bryan22's Avatar
while you're at it replace the 2 silicone based hoses. Go to ford and get the right ones. Vaccum lines will dry out and fall apart in a few days. This is coming from my personal experience. I think i paid 8 dollars a foot. Pricey yes, but they will last a long time. 16 bux well spent.
Old Dec 13, 2008
Mark98xlt's Avatar
Its either one of the other when you get the egr code, I replaced my egr valve on my 3.0 light came on the next day for the same code replaced the dpfe and the light went off for good.
Its hit or miss when fixing the issue its best to just replace both at the same time they are each around $50 a piece.
Old Dec 16, 2008
Bryan22's Avatar
the EGR valves don't really go bad very often in most cases I'd bet on the DPFE.
Old Dec 16, 2008
marcua56's Avatar
ha thanks guys i went to ford and they wanted 120 for the sensor and then the autozone next door had it for 49.
Old Dec 17, 2008
texasfan1000's Avatar
I had the same thing. I replaced the hoses and found a crack in one of them that you could not have seen with them still hooked up.
Old Dec 17, 2008
Bryan22's Avatar
you might have saved a few buck, but when the autozone special goes out in 6 months replace it with the ford one that'll last 10 years :)
Old Dec 17, 2008
Ford04Ranger4.0's Avatar
I'm about do replace my DPFE sensor bought a brand new FoMoCo one for $60 at a parts store
ryan_88
Sep 23, 2021 02:41 PM
ramblinrover
Jul 1, 2011 07:46 PM
jmshanafelt
Jun 22, 2011 08:20 PM
Nestromo
Sep 22, 2010 10:51 AM
i_love_paintbal
Dec 18, 2007 07:37 AM
