2003 3.0L - To Those Who Still Have Fan Clutches & Have Replaced Yours Already (pics)
Old Dec 16, 2008
HELMUT RONER's Avatar
Icon5 2003 3.0L - To Those Who Still Have Fan Clutches & Have Replaced Yours Already (pics)
Was the shaft portion on your replacement fan clutch bigger than the factory one?
DSC00771.jpg?t=1229484976
The shaft on my factory one is smaller requiring a 7/8 size wrench.
At the shop one of the mechs there was trying to tell me that this one is too big to go back into my truck. I didn't want to contest him because he's helped me on a few things before, but he has instilled some doubt into my mind. I tried for the second time today to remove the old fan clutch and was unable to get the old one to budge. Nothing the shop had was able to hold the water pump pulley from turning. We used a hammer on the wrench to try shocking it loose, but no go.The mech was looking at the new fan clutch and was saying the threads are too large. I'm wanting to think the threads are the same, just that the shaft was smaller on the old one. Any feedback on this?
Old Dec 21, 2008
stRanger's Avatar
Ok, on my 1995!!! for ranger... the threads were left hand thread (left tighty, right loosey :) ) Anyways, I took essential a big chisel (dull) and a 3lb sledge and set the chisel on the right side and popped a couple hard times and it came loose, same way to tighten it back up..
Old Feb 21, 2009
I found out yesterday that as you're looking at the engine from in front of the truck the direction to screw on and tighten the fan clutch is COUNTER CLOCKWISE. I stopped by NAPA and asked for a water pump for my truck. They had it and I test fitted the clutch to the pump. So, it turns out that I was trying to unscrew my old clutch in the wrong direction. I hope this helps others in the future.
Old Feb 21, 2009
whippersnapper02's Avatar
I'm about to change mine out today. Thanks for the info.
Old Feb 21, 2009
Yeah its reverse thread. I put tension on tensioner and popped it lose with the wrench, super easy.
Old Feb 21, 2009
Well I just tried to change it but no luck. The fan clutch tool kit I rented has too big of a wrench for the nut. Oh and on a 4.0 its counter clockwise to loosen it.
Old Feb 21, 2009
wvcat's Avatar
I used a pipe wrench on the water pump hub to hold mine...no problem afer you get it in there
Old Feb 21, 2009
I can't change it for the life of me. The tool kit they rent doesn't have the right size and I can't find the right size wrench to get it off. I even bought an adjustable wrench and it's not big enough.
Old Feb 26, 2009
FINALLY
I finally got the darn thing in. I love how quiet my truck is now. My exhaust is totally stock, but now has a nice deep tone to it and I got back a ton of power.
The new fan clutch requires a 36mm or 1 and 7/16 wrench.
Old Mar 2, 2009
Slevin's Avatar
Good rule of thumb for fan clutches is, if it is a smooth pulley, then it removes counter clock wise, (right hand thread). If it is a grooved pulley, then it removes clock wise (left hand thread). And the best tool ever to remove them is this one.
http://www.handsontools.com/Lisle-43...html?iorb=4764
yes you will need an air hammer, but it will get ANY fan clutch off.
Old Mar 2, 2009
Just for these Rangers I'd prefer the wrench I bought and a strap wrench around the water pump pulley. It was so easy with these. I didn't have to hold the strap wrench during removal. The handle of the strap wrench is pushed against the alternator pulley during removal so I didn't even have to hold it as I turned the fan clutch. With the new fan clutch I dabbed some anti-seize compound in the threads. So far so good and she runs like a dream.
Old Mar 2, 2009
fx4818's Avatar
after changin a few ranger motors i decided to buy the fan clutch hub nut wrench set from advance auto to change the fan. probably the best $24 ive spent in quite a while
Old Mar 2, 2009
StrangerRanger's Avatar
Doesn't it say right on your rad housing that its left hand thread? It does on my 2000? Hmm..
Old Mar 7, 2009
No, it sure doesn't. No stickers at all anywhere on the shroud or the radiator support.
Old Mar 7, 2009
Icon7 Videos of the Annoying Bad Fan Clutch
http://www.youtube.com/watch?v=jwO1KeyJ460
http://www.youtube.com/watch?v=mCQQdAbSj48
http://www.youtube.com/watch?v=tMToHYp3CmQ
Finally after replacement.
http://www.youtube.com/watch?v=FqZoCyRaLJk
Old Mar 9, 2009
GER42's Avatar
I need help
Trying to replace my fan clutch.
Got this tool can't figure out how o use it to remove the old one
[IMG][/IMG]
Where is supposed to go?
How do I stop the water pump pulley from turning?
It's righty loosey on this correct?
[IMG][/IMG]
Old Mar 9, 2009
I tried with a kit like that and couldn't figure it out, either. I bought a strap wrench at Sears. It has a rubber strap unlike the orange plastic one pictured near the top of the thread. Grips much better and made this worlds easier. I don't use the terms lefty or righty because they are not understood the same way by everybody (if that makes any sense). Clockwise or counterclockwise (as you look at the engine from standing in front of the truck) are better understood by most everyone.
Old Mar 9, 2009
GER42's Avatar
Clockwise to get off? I tried using the rubber strap I have but I could not get it tight enough to stop the pulley from moving.
Old Mar 9, 2009
Yes, clockwise to get it off.
Old Mar 9, 2009
The big square end goes around the pulley bolts and you attatch a breaker bar to it if it is just the head.
My clutch isn't stuck on but it squeaks in the morning when I started. At first I thought the water pump was going but I stopped the fan and the squeaking stopped.
Old Mar 9, 2009
This is the wrench I bought at Sears. $15.
http://www.sears.com/shc/s/p_10153_1...d=strap+wrench
Old Mar 9, 2009
There were no bolts in the pulley unless you're refering to the 4 bolts that attach the clutch to the fan. The bolts are too short for the kit that I tried. The wrench to hold the pulley was too thick and wouldn't allow me to thread the bolts back into the clutch. I'd bet the same would happen with GER's kit.
Old Mar 9, 2009
No it goes over the bolts that hold the pulley to the water pump.
Old Mar 9, 2009
I never saw any on mine. I'll have to take a better look.
Old Mar 9, 2009
I just looked it up on www.napaonline.com. They show the actual part for most of what they sell instead of representative images. The pump does have four threaded holes, but as mentioned I never saw bolts on mine.
