door ajar...nothin works!
Old Feb 3, 2009
sarasota4x4's Avatar
so i have almost had my truck a year now. the first day i got it i pulled the dome light because of the door ajar. a few months ago, i tried the wd-40 trick... didnt work. i sprayed it into any hole, tab, piller. ANYTHING.
i am really started to get sick of pulling out the maglight every time i need light.
maybe something else is required due to the four door?
also, my weather stripping on the pass. rear door is messed up... could that affect this?
thanks!
Old Feb 3, 2009
FullThrottle02's Avatar
You probably are going to have to replace the latch assembly if everything else has failed. If the p.s rear door is not closing completely it could cause the light to come on.
Old Feb 3, 2009
replace it, prob broken also order some new seals from LMC truck
Old Feb 3, 2009
99offroadrngr's Avatar
TOYOTA
mine wouldnt go away yesterday when i was doing the WD40 trick but i just sprayed a bit more everywhere and started slamming all 4 doors and then it was fine. i found it to be the passengers side that caused the problem.
Old Feb 3, 2009
replace what, exactly
Old Feb 3, 2009
I believe the latch is where the 4 door trucks have there door ajar switch
Old Feb 3, 2009
http://www.trademotion.com/partlocat...=4&catalogid=2
Old Feb 3, 2009
Crunchy's Avatar
I had the same prob, make sure you shut your suicide door completely. Try to pull in & out, it may still have some give in it - meaning your lower latch didn't catch completely. I know for mine I have to push firmly from the bottom or it will not latch.
I think its cause of a cancerous tumor (rust) starting to form in my lower latch on the rear door.
Old Feb 3, 2009
Motorcraft's Avatar
i had the same issue on the pass side of the truck.... i just cut and capped off the wire. dont really need the light to come on when i get into my truck.
Old Feb 3, 2009
goliath553's Avatar
My dad has an 01 with this prob... he did the same thing removed the dome light. I believe his prob was the suicide door, it had something to do with the way it closes. The ring on the floor of the truck or something that needs replaced but he didn't want to spend the money.
Good luck.
Old Feb 3, 2009
thats what im talkin about!
how do i know i cut the right wire, though...
Old Feb 3, 2009
Motorcraft's Avatar
i cannot remember the color. i used a test light and opened and closed my working doors to see what wire got power when i opened it and cut that wire on the other side.
Old Feb 3, 2009
Gallo75's Avatar
4 doors and 2 doors are the same, it's the stupid door latch light switch or whatever you call that thing, you just need to remove it and clean it, the first time that happened to me i bought it and it only lasted a few months and it started doing it again, i just take it off the latch assy and press the thing a million times while spraying it with whatever i can find, it works great everytime i just don't know why it gets dirty again, actually i was thinking about doing it again today, i'll take pics of the process HTH!
Old Feb 3, 2009
DaGGer's Avatar
I had that problem, I used Silicon spray in the door jam for about a week and slammed the doors quite a few times and it went away haven't had it come back at all.
Old Feb 3, 2009
Blackonblackfx4's Avatar
My ranger was doing that i brought it to ford and they sprayed all the latches with liquid silicone or some lube, and slammed all the doors a bunch of times and it fixed it
Old Feb 3, 2009
Toreador4x4's Avatar
make sure you apray all 4 latches and slam the doors alot (30 times) use pb blaster it seems to work faster
Old Feb 3, 2009
Gallo75's Avatar
this is the little bastard that you need to clean, or you can find them on ebay for $8
Old Feb 3, 2009
thanks for the help. i get off work at 2 tomorrow so i will spend my afternoon slamming doors
Old Feb 4, 2009
Slevin's Avatar
if you do end up replacing the switch it self. i found it easier to replace with the latch in the closed position so you are not fighting the return spring on the switch.
Old Feb 4, 2009
ColdNapalm's Avatar
ya my single cab ranger had the same prob just pulled the fuse and used a flash light...
mx98ranger
May 1, 2017 07:54 AM
woody99stpsde
27
Feb 11, 2009 05:13 PM
Matt3203
Nov 5, 2007 10:31 PM
Black98Ranger
Jun 9, 2005 09:15 PM
SilentNoise
Jan 31, 2005 11:13 PM
