Starter problems
Old Feb 10, 2009
Hardy Har 16's Avatar
Starter problems
so i go out to leave for school this morning and i go to start my truck and the ignition is completely locked tight and i try to play with it and the wheel and stuff but it wold budge at all...so i was wondering if anyone had any ideas how to fix it...also my remote starter starts the truck just fine its just my ignition is locked help please
Old Feb 11, 2009
Rolldogg's Avatar
1st off, you only need to post 1 thread in 1 section. Having 3 identical posts in 3 different sections is just bad news waiting to happen.
2nd, the thread titile needs to be clear and correct. The problem isn't with your starter, that located under the engine. Sounds like your ignition switch is locked.
o.k, so keep giving your wheel a shake and turn. Just sounds like the ignition is locked. Wiggle the ignition with the key in it while jiggling the steerign wheel. Should unlock for you.
Old Feb 11, 2009
zax's Avatar
zax
my old car used to do this every once in a while. I would just pull on the wheel to the left or right as much as i could and try to turn the key at the same time.
Old Feb 11, 2009
Yep sometimes the truck just gets angry for one reason or another. A little bit of wiggling should take care of the problem.
batousil.
May 26, 2009 07:16 AM
batousil.
May 24, 2009 03:18 PM
Hardy Har 16
Feb 11, 2009 06:39 AM
Hardy Har 16
Hawklore
Sep 7, 2007 09:02 PM
