sliders
sliders
made these this weekend. legs are made of 2"x 2" x 11 ga square tubing and the other is 3" x 2" x 11 ga rectangular tubing. had some different angle cuts but you can see it in the pic...
took me a while to get it right...
all of them made and tacked together..
everything tacked together..
crappy cell pic of one of my welds...not the best, not the worst. itll do though..
done.
done.
weld them.....i wanted to bolt them on but i couldnt. just ended up not being an option...
i have a pic of it somewhere....just cant find it.
a buddy of mine wants a set kinda similar so when i make his i will make it bolt on.
i was originally gonna use round tubing but somehow decided to use square tubing. i even have the round stuff still in my garage. oh well.....square is definitely easier to work with
lincoln. little flux core welder. def gets the job done. if i need a bigger welder i go to my uncles and use his miller.
Looks like the same sliders that I am thinking of lol. Looks like they are going to cover alot, and save your rockers. Square is the way to go, much easier to work with, and I think it looks better.
when could I come down to get a set?
most likely not.
Im saving money go to to Port A monday-wed, and now on the drop of a hat we're going to Boulder friday, anddd I'm going to be going to college station thursday, so im all booked up to spend all my monies.
what did you do?
i just got some limit straps hoping that cures the problem with my yanking the yoke out
most likely not.
what did you do?
most likely not.
what did you do?
most likely not.
what did you do?
if you want to come down and get a set come on. i work a metal building components place now so i get steel for pretty dang cheap. we can make a set in a day now that i have all the measurements. lol
what kind of driveshaft are you runnin?
Looks good!
I know it doesn't matter too much really for you, but most of the time when doing an angle on two parts (like on your 'legs' to the frame), people bisect the angle, cutting it on each part (you've got a 10* and 15*...should be 12.5* and 12.5* cuts). that way you get two surfaces that are identical and mates up perfectly (one side isn't bigger than the other like you've got it now). Basically makes a nice mating surface and welds better.
