How To: Rear Gap Guards
Old Mar 15, 2009
Yellow_edge_4x4's Avatar
Tired of seeing this??
Then this is for you. First go to home depo and pick up some step guard. It should be around $10. Also get some self tapping screws while you their.
Roll it out and let the sun heat it up a bit. It will make it easier to work with.
Measure from front to rear of the wheel well. Then from the fram to whell well. Add those together and cut the step guard to lenth.
Then measure from top to bottom. And cut the lenth.
Start with the rear of the wheel well. (Pre drill for the self tapping screws) Then pre drill in the plastic for the retainers.
Continue along the top rail to the front of the wheel well and do the same for the front as you did for the rear.
You could be done at this step, but I did one more step to make sure the guards woudn't rub into the tire while driving.
On each side of the fram theirs two holes that you can use zip ties to hold the guard. I like using the zip ties because on the driver side youll run into the gas lines, didnt want to mess up the lines.
You dont have to have the zip ties all the way tight. You just want it to hole it in place and not go towards the tire.
Go to the other side and repeat, now you done and can enjoy no more gap.
Old Jan 3, 2013
al lafon's Avatar
Icon14 A good Buy !
Hello going to do front and back on my ranger.
Thanks Al
Old Jan 5, 2013
green99's Avatar
Looks much better! I would paint those self tapers black, so you can't see them.
Old Jan 7, 2013
al lafon's Avatar
Icon7 gaurds
I plan to use push pins the locking ones.
Old Mar 11, 2013
Scrambler82's Avatar
Old Guy User…
Just saw this, good idea.
jerrod07
Nov 2, 2006 07:50 AM
shadyluke
23
Oct 8, 2006 05:17 PM
rangererv
Feb 17, 2006 02:43 PM
Ranger1
Feb 17, 2006 08:31 AM
Mason
Aug 4, 2005 02:29 PM
