2wd lift idea?
Old 02-05-2006
ike34's Avatar
2wd lift idea?
I'm thinking about lifting my 2000 xlt ext cab 3.0L ranger. I have been doing some reading and I think this is what I would like to do
Front
3" lift springs
3"lift spindles
new upper arms
Rear
4" blocks
maybe AALs but it should be level because the back is taller stock?
Shocks
Explorer pro comp es3000 should work right?
Wheels and Tires
15x10s but what backspacing should I use?
BFGoodrich Mud Terrain tires 35x12.50x15 they should fit right?
What gears should I get to make my truck run like it does now (stock) 4.56s or 5.13s?
also I going to get a powertrax for the rear end.
And down the road I might add coil spacers to the front and AAL if I dont do them when I do this, so it would be about 7-8 inches of lift
Sorry for all the questions and it being so long and tell me what you think
Thanks
Old 02-05-2006
if your planning on getting 6" with the lift coils and spindles its going to screw up your camber royaly...
and if your going to use 4" blocks your going to want to think about getting some traction bars to prevent axle wrap
Old 02-05-2006
KARPE's Avatar
dont do 4 inch blocks, your axle wrap will be unbareable, do some chevy leaves, and a smaller block, possibly chevy shackles too but some say they are too weak for heavy wheeling.
and I recommend going with a 15x12.5 rim and 35x1 5x15, wider is better!
Old 02-05-2006
ok two things the chevy springs are lot stiffer and arnt the best of ride the best way is a like Deaver leaf pack its a little more $ but you get what you pay for. and the next thing
he cant fit those wheels are tires that comment isnt needed it confuses people who dont know more then anything.
Old 02-05-2006
ike34's Avatar
I also am thinking about the rcd kit, is it a good kit, what do you think of it?
Old 02-05-2006
you have a 2wd truck the RCD kit is ment for 4x4's. sorry...
Old 02-05-2006
ike34's Avatar
I was just at there website they have a 2wd kit, its a 6" lift
Old 02-05-2006
fabtech has a 5.5" ultimate kit, we offer it at jusnesmodified.com, includes shocks and everything else you need
Old 02-05-2006
that lift is new to me alright just now noticed it. anyone know when they brought that lift out?
looks decent to me i would get it if it isnt like a billion dollars
Old 02-05-2006
heres the setup im working on
front:
fabtech 2.5 lifting coil
fabtech upper arm (to go with the coil)
3inch liftin spindle
Rear:
explorer 4x4 4dr leafs
belltech chevy lowering shackle
Add a leaf
and a 3inch body lift over all
honestly, with your 6inch suspension lift i dont know if you able to run 35s, 4x2 lare lower stock compared to the edges and 4x4 since they have a different front suspension and a factory 2inch block in the rear, so they have a 2inch head start compared to you... You might have to do a full 9inch lift to run 35s
Old 02-05-2006
johnson's Avatar
I have 6 inches of lift up front on my 199 2wd XLT and i have 33x10.50's. Theres 10 inches of clearence. It will work but it will be tight and rub a LOT. You should also do a 3 inch body lift if you are running 35's. And maybe some wheel spacers. It takes a lot of lift to fit 35's.
Old 02-06-2006
ike34's Avatar
I was also thinking of a 3 inch body lift too, with the rcd kit
Old 02-07-2006
8lugZJ's Avatar
Man...alright, so you are talking about lifting your 2WD 9" and running 35's...why? I'll go ahead and be honest with you, from experience. Driving a lifted truck/SUV to that extent is fun, for about a month IF all you can do with it is cruise the parking lot at the mall (which is all yours would be good for). The only reason to have something like that IMO is if you can actually use it, so why not just buy a 4WD truck
Old 02-07-2006
a311fanam's Avatar
i agree with 8lugzj, since your truck is 2wd (like mine) in my opinion, there is no need for a huge lift. I do plan on getting a powertrax too. If i were you, i'd say get a 3" lift of some sort and make it about a edge height, and run 31's or 32's. But honestly i wouldn't go crazy with a lift.
Old 02-07-2006
n3elz has 35s on his 2wd edge, and hes offroaded alot more then more 4x4 guys
also, you need to realize that a 9 inch lift on a xlt is compared to a 7inch lift on an edge
Old 02-08-2006
ike34's Avatar
Ok
I think I'm going to go with the RCD kit and a 3 inch body lift.
But I have 2 more questions, with 15x10 wheels what backspacing should I use and I think I going to go with 4.56 gears will there be any noticable power difference with 35s vs stock?
knsdrms3
19
06-03-2009 08:05 PM
UNCCRang49
31
10-20-2006 10:58 PM
ike34
09-06-2006 08:42 PM
ike34
08-31-2006 04:34 PM
KyRanger
06-19-2004 04:52 PM
Quick Reply: 2wd lift idea?
