Sponsored by: DashLynx
wheel well splash guard ?
Old 05-20-2006
stockranger's Avatar
I noticed my passenger side has a rubber splash guard that hangs down in the front wheel well but the drivers side does not . I see where there are holes which looks like there used to be rubber attached . Is there supposed to be one and i just lost it on the trail?s ? Is it something which i should be concerned about replacing ? i know its been gone for atleast 6 months because it wasn't there when i extended the front diff vent .
Old 05-20-2006
yep they used to have them then ford for stupid and saved $ by not putting one in. head to a junk yard pick up a passanger side one and flip it around and mount it up or go to the dealer and pay some huge price and buy the driver side one.... it will really help keeping the mud out of the engine bay
Old 05-20-2006
Mr. Special's Avatar
Either find one at a junk yeard, or i just went to Home Depot, bought some heavy duty rubber matting stuff and used the passanger side one as a guide and made my own.
Old 05-20-2006
Originally Posted by ericsmith32
I wonder what they were smokin when they thought of that.
The driver side splash guard was shotened about 2002 to help lower underhood temperatures during desert testing running high volatility fuels. A couple of years later, it was deleted completely. Ford has to build vehicles that will perform well in a wide range of worst-case conditions.
Since I don't live where it's extremely hot and I don't run gasohol, I installed a second PS guard on the DS. The PS shield is identical to the DS shield on earlier models except the pins are pushed in backwards. The added shield keeps the engine compartment MUCH cleaner in muddy conditions. A very worthwhile mod.
Don't bother trying to order a new DS guard from an earlier model Ranger (like I did the first time, LOL). The part number has been superseded to a 1/4 length guard that is completely useless. Just go to a junkyard or order a new PS guard from the dealer - mine cost $14 new a couple of years ago.
PS part number: F87Z-16102-AA
That is the correct number for my 2003 and I would guess that newer trucks use the same.
It also helps to reverse the push pins and install both of the splash guards on the inside of the plastic inner fenders instead of the outside like they are from the factory. That way, they don't get ripped off by the tires as easily when offroading.
You will probably need to repunch the rear two holes in the rubber to get everything to line up - easy.
This simple mod gives extra clearance and, just as importantly, hides the prominent top edge that the tires like to grab hold of while turning.
Here is the remounted shield. At the top of the photo, you can see the "witness mark" on the inner fender where the splash shield used to be on the outside:
This view shows the inside of the inner fender with the reversed push pins and the repunched holes. (You don't need to pull the inner fenders to reverse the shields. I took this picture when I was installing headers and had the inner fenders off for access):
Swoop discovers the "missing" splash shield. Look at the underside of the hood and notice how much more mud made its way into the DS of the engine compartment:
Old 05-20-2006
doug435's Avatar
looks like my 2000 after i got home one time
Old 05-21-2006
I do alot of driving in temps over 100 in the summer time . I avoid mud and water as much as i can but of course there is always a relentless cloud of dust when wheeling. ... our gas in cali has alot of ethanol in the summer too . So maybe I should just leave it with no drivers side splash guard ? what do you think bob ?
Old 05-21-2006
The test is done in Arizona with zero wind, full sun load, at or above 100F, with out-of-season fuel. There are long periods of slow speed driving, then idling and engine off within an enclosed parking area. After the idle and after the hot soak, the vehicle is accelerated and rated for driveability. If it is unacceptable, something in the design must be changed to improve it.
It is important to understand that this test is not about overheating the engine; it is about overheating the fuel in the engine compartment which can cause driveability issues.
Quite frankly, it is an extreme test that you are not likely to duplicate often, if ever, regardless of where you live in the U.S. However, Ford sells vehicles for all conditions in the intended market and must react to worst-case scenarios and adjust accordingly.
If I had any problems such as mud in the engine compartment because of the lack of a splash shield, I would install it. I would gladly trade the tiny chance of a driveability problem in extreme conditions for a cleaner engine bay.
Old 05-21-2006
rangererv's Avatar
SeanL
08-31-2016 09:41 AM
nvpatty1
06-09-2015 07:38 AM
SVT01RANGER
09-08-2009 10:15 PM
JakeH05
04-29-2008 06:10 PM
adamg
01-29-2008 05:02 PM
Quick Reply: wheel well splash guard ?
