TPMS question
Old 07-14-2008
ns_red7's Avatar
Icon4 TPMS question
If I put a set of rims on my tpms equipped 07 and they don't have the sensors, am I going to have a light on my dash on? Is there any way to disable this warning?
Last question: what year did the tpms show up on rangers...?
Old 07-14-2008
dakota772's Avatar
I believe 07 is the first year for the sensors, someone please correct me if I am wrong. Also, as far as I have heard, you cannot disable the sensor with a tuner or any aftermarket tricks. Of course this information could be out dated, please someone correct if I am wrong.
Why did I post anything if I am not sure about anything?
Old 07-14-2008
ManEHawke's Avatar
You will have the light, and I have yet to see a way to disable it with the IDS. (pull the bulb lol)
You can use your TPMS sensors on you current wheels, and transfer them over, and they will work. You will need new clamps, but its up to you if you want to be creative and use somthing cheap like wire. Hey it works, those clamps are like 15 bucks each.
Old 07-14-2008
malydeen's Avatar
You will need to transfer the tpms. Depending on the design of your rims are now and what the new rims are you SHOULD be able to reuse them.
Old 07-15-2008
ns_red7's Avatar
What a pain in the azz. I googled tpms removal and it showed threads from many different forums, apparently there is a lot of people who have this issue. There should be a way to disable it...
Old 07-15-2008
yetti96's Avatar
It was put in place for every automaker for a reason. People are dumb, drive on under inflated tires, lose control of have a blow of and people die and property is damaged. Every vehicle built after Sept 07 is required to have them.
Old 07-15-2008
graniteguy's Avatar
I'll have to admit that the tpms saved not only a tire, but probably my fender. I was at hiway speeds when the light came on. The tire was losing air fast. That sensor gave me time to pull over and watch it finish going flat. The other option was going flat at hiway speeds.
Old 07-15-2008
ns_red7's Avatar
I don't really care to discuss the merits of this system. I just want to disable it so my other rims with the mud terrains on them don't set off a light.
Does anyone know if this is a reqiurement on this side of the border?
Old 07-15-2008
muscleford's Avatar
I just changed my wheels. The clamps from the dealer quoted $55 ea the tire shop charged me $20 and change per wheel.
Old 07-15-2008
dakota772's Avatar
I don't think so, this is only an American problem so far. But I am sure it will spread to other countries like a disease.
Old 07-16-2008
SanityAside's Avatar
you can switch the sensors to the new rims
ecrase2500
12-17-2009 08:44 AM
ShadowRanger08
12-07-2009 04:33 PM
HerculesII
20
11-10-2007 12:46 AM
07Ranger
11-08-2007 09:12 PM
ScottG
10-19-2007 02:49 PM
Quick Reply: TPMS question
