Rotating tires quick question?
My tires are about 3k over due, and I need to rotate them so the wear will be even all around. I searched but couldn't find the answer, do the rear tires need to be re-weighted when you swap them to the front? Also what kind of pattern should i go in, should I swap the fronts with the rears and go in a criss cross pattern once there swapped? or just plan old swap the fronts with the rears and vice versa? Thanks for the help.
If you're not including the spare in the rotation, and your tires are not directional:
RR to LF, LR to RF, LF to RR, and RF to LR.
Some may have a different idea but this will ensure that each tire spends time on both sides of the truck, as well as front and rear. Also evens up the time spent as a steer tire and drive tire, hopefully resulting in even wear and long life.
As long as they are properly balanced and stay that way, there is no need to redo the balancing when changing the tires position.
another tip. if you can avoid it dont go peeling off or slam on the brakes right after you get them balanced. sometimes when the lube hasnt dried the tire can shift a little bit throwing the balance back off
Yeah I don't really due either so I think they will be all set. They were weighted and balenced last november when I got the tires and rims mounted up so I'd say its been a while, got them put on the truck at 71k I have almost 77k on it now so.. I'll rotate them myself and get an app to get them balenced again.
whichever you do just dont cross the fronts AND the backs because the next time you rotate and do the same thing the tires will just end up back where they started. Doing like this by moving rears straight back then crossing the fronts, or vis versa, allows all the tires to be used in every possible configuration. Either way stick to whichever pattern you use.
