Body lift waag bar process.....(updated daily)
Old Nov 4, 2005
rangererv's Avatar
DAY #3...post 26
DAY #2...post 12
Ok, i spend most of today working on these brackets.
I removed the skid plate and bumper, put the main bracket on the frame and worked from there. After an hour of just simply studying the front end of my truck and the brackets, i came up with how to make the bottom brackets.
I still havent thought on how to do the top bracket, but once i finish the bottom i will think of something.
Im just waiting on material that i will get tomorrow for the bottom.
What i have came up with so far for the bottom is a simple bolt on piece to the main frame bracket. From there i plan to use the "Stock" brackets that come with the kit...only you have to switch the driver and passanger around, and turn them upside down...
I have made a templete out of wood for the piece that i am making, however i drilled the wholes wrong. I have been discussing this with my dad and we have figured out how to make it work easily.....just making the first one will be a pain.
I dont have any pictures right now, basically just planned out today on what to do (there was a lot more planning then expected).
Tomorrow i will finish up the bottom brackets and start on the top.
I can see that the top will be hard. The bracket has to go between the bumper and grill, and there isnt much room. It can be easily done, but the bumper will be so low, that it will look ugly...(almost 1.5 inches gap).
Im thinking i may have to customise this bracket, but i have to finish the bottom first.
This post will be updated daily, ,or maybe twice a day.
I will have pic once i start making parts and putting them together.
any suggestions or help facts, let me no please...these bracktes are HARD!!!
ill keep you updated.
Evan
Old Nov 4, 2005
hey evan give me a call tomarrow btw you coming to Mike A's house?
Old Nov 4, 2005
Sweet wish I still had my waag bar!
Old Nov 4, 2005
rangererv's Avatar
Im not sure...i dont no if im going to need to....possible just a bolt on piece that im making..
Ill call you tomorrow morning and you can stop buy if you want. My dad will have the material i need at 11 (lu
nch brake from work)
Old Nov 4, 2005
Have pics of the wooden piece?
Old Nov 4, 2005
rangererv's Avatar
no sry...
i took it all apart to remeasure for the actual piece....i will post pix tomorrow of what im talking about, cause its hard to picture what im doing.
Old Nov 4, 2005
No worries can't wait to see it!
Old Nov 4, 2005
01xltranger4x4's Avatar
Sounds good evan............Lucky you got $$ to mod, i dont lol...
Old Nov 4, 2005
04lvl2's Avatar
Evan, my boy give me a call tommorrow as I would like to come down and help aka make some for me too.
Old Nov 4, 2005
rangererv's Avatar
^^ ok bill sounds good.
Im pretty sure what i have going is going to work...however not 100%
Once i get mine 100% on ill take all the brackets off and doublicate them for ya.
ill call you tomorrow if you want to stop by..i think zach might as well.
Old Nov 4, 2005
rangererv's Avatar
hah ya money helps a little bit
Old Nov 5, 2005
rangererv's Avatar
Ok, i got my metal pieces that I need today.
it is a 10.5x2x1/4 in piece of metal.
drilled a hole at the bottom to connect to the main "stock" frame bracket.
I bolted these pieces together
I only have one hole drilled for now untill i can align it perfect, then i will mark and drill out another hole.
Then i connected the PASSANGER bracket that sticks out of the bumper to the DRIVER side bracket. The bracket must be turned upside down.
Once i align and level the waag, a new hole must be drilled to attach the bracket to the waag. (one hole will line up, but the other will not)
ok gotta go finish..
Old Nov 5, 2005
Looks good, and the mechanics creeper is you friend lol...
Old Nov 5, 2005
rangererv's Avatar
haha ya it is.
i need a lifted creaper tho...still have to reach way up...lol
Old Nov 5, 2005
rangererv's Avatar
i have the bottom brackets made and drilled out.
things are going smoth so far.
I have an idea for the top brackets to connect, but well see. I gotts get a piece welded tomorrow.
Dont no if i will be able to update it tomorrow cause i have to work..well see
Old Nov 5, 2005
u aint done yet?
Old Nov 5, 2005
u aint done yet?
you cant rush art..lol
looks good Evan..
cant wait to see the final product
Old Nov 5, 2005
You can rush anything! Looks like things are going smooth man!
Old Nov 5, 2005
04lvl2's Avatar
Looks good in person as well. Once the upper mounting locations are extended then it will be done pretty much.
Old Nov 5, 2005
what kind of metal did you use?
Old Nov 5, 2005
rangererv's Avatar
u aint done yet?
lets see you come and do this...lol
im doing one part at a time and i am mostly waiting on material.
plus its the weekend...um partying...lol
1/4 inch thick steal
tomorrow i am getting 3 inches welded on to the top of the brackets, once i finish that, it should be a smooth finish. (knock on wood)
I have finished the bottom brackets completely today, no pix yet tho.
Maybe tomorrow, but i am pretty busy all day.
Shoud be totally complete by monday or tuesday, and i will take tons of pix and measurements for you all.
Old Nov 5, 2005
kerv's Avatar
u still aint done??? i came over at 2 and u had the bottom mounted damn dude ur slow and lazy lol
Old Nov 6, 2005
01rededge's Avatar
Andy - If you still want one, mine is off and I'm not putting it back on......
Old Nov 6, 2005
evan come on man... saturday i completly designed my new hitch... its currently all welded up and waiting on some primer and paint.
Old Nov 6, 2005
rangererv's Avatar
you have a welder at your house...i dont.
i had to design the parts, then wait untill my dad took it to work to weld it.
