Run at Fast Idle?
Old Aug 16, 2005
Engine Flush Question - Run at Fast Idle?
I gotthe Amsoil Engine Flush and it says to put in engine and run at fast idle for 15-20 minutes. Does that mean to give it alittle gas or just let it idle by itself.
Old Aug 16, 2005
yes i would imagine prolly nothing over 1200-1500 rpm
Old Aug 16, 2005
^^^^^^ Yea that is what I just ended up doing truck runs great now with the amsoil.
Old Aug 16, 2005
034x4's Avatar
DO NOT DO AN ENGINE FLUSH!!!
Every single car that has come to work for an engine flush comes back 5-10000 miles later with valve noise! All the carbon/buildup gets broken up in the engine and clogs the oil pump pick-up. Therefore decreasing flow of oil to the rest of the motor. I hope i posted this in time.
BTW for reference, i am a Tech at a local dodge dealer so i'm not talking out my ***.
Well i just read that you already did it...sorry i posted too late.
Old Aug 16, 2005
It seems like it is running much better than before.
Old Aug 16, 2005
GrafixGuy's Avatar
then how would you change over to synthetic oil???
Old Aug 16, 2005
SoundPer4mance's Avatar
you dont HAVE to flush to change, but if there is buildup that could potentially damage the engine, then there is ALREADY a problem that needs to be fixed. using the flush will not CREATE this problem, rather allow it to occur sooner than it would. even then you would need a LOT of buildup to be solid enough to stay solid in the engine and clog the oil pickup. that much buildup would need to be addressed at any rate.
Old Aug 17, 2005
TheManInBlack's Avatar
snake oil there I said it LOL
DougS
Sep 26, 2013 05:55 AM
TurfRanger
May 5, 2012 07:26 PM
redrangeradrian
50
Apr 16, 2009 03:24 PM
neptuniregis
Mar 21, 2006 03:48 PM
ranger024x4
Mar 1, 2005 10:56 PM
