fast clicking noise
fast clicking noise
I have been having a really fast clicking noise in my engine when I rev and when I accelerate. Its pissing me off. I tried to determine where the noise was coming from but I had no luck. Has anyone had this problem before. I have a bama chip could it have something to do with that? Also when I checked my oil it was low and I had to add more, but I haven't noticed any leaks at all. Does anbody have a clue on what it might be?
exhuast leak...is more than likely what it is...does it do it very quitley when its idleing???? and whenever you give it gas or keep it at a sustained speed with highr RPMs it clicks?? if so...it is more than likely an exhuast leak...I have had to take mine in twice so far...and its doin it again, i dont think it hurts anything, its just like u said annoying...LOL...its not much to get fixed usually just a gasket on your manifold or also underneath ur passenger door where the exhuast pipe comes out theres a connection, it has two springs on both sides and a hard wire mesh gasket there, that could be bad...but most of the time it comes from your manifold, you could try to make sure ur manifold bolts are tight...thats what I think it is...
Originally Posted by DUB Offroad Edition
timing chain rattle??? mines got that....
Where are the egr tubes at? I took it into meinke and they said that it wasn't an exhaust leak. It is also not the timing chain. This scares me because they said it was an engine noise. It might be the main bearing. I hope not. I also checked the a/c and didn't notice a difference in the noise. It was exactly the same. Any other ideas?
Guess what? ****! MY WORST NIGHTMARE CAME TRUE! #1 piston was knocking which sucks! I change my oil every 3 thousand miles and there was no leaks. Ford said that they are gonna probably help me out since the car only has 40000 miles on it which is good, but an engine still shouldn't do that at that milege. I dunno what I am gonna do. Anybody got an engine sitting around?
I have the same type of noise, except it only happens when I accelerate..Not while idling or at high RPM
I'm officially gonna freak out now, since I just had the tranny rebuild, and transfer case motor replaced under warranty 56k miles on the truck. cost was 3700 bucks, I still had to pay 350 bucks out of my pocket
Now and engine ticking noise....
Prerunner-Ranger
04-28-2008 05:32 PM
JASONGR81
12-11-2006 08:33 PM
