6" skyjacker lift build up.
Old Nov 29, 2006
blackbetty's Avatar
ok so last week i got my 6" lift from skyjacker but i couldnt start till sunday due to shi**y weather. So here is a bunch of pics of progress..let me know what you think.
passenger side beam unbolted and rivets heads got punched and drilled.
here is how it sits stock.
off topic but can anyone tell the difference in this pic from the top one?
here is the drivers side all connected.
here i started by disconnecting the b-lines, unbolted the shock, cut the spring and supported the pig underneath.
here is the length of the uncut spring.
heres the old center hinge
new center hinge bolted up.
heres another shot of the bracket.
here is the old and new drop bracket for the drivers side.
and here the bracket partially installed.
here is the new and old pitman arm.....for those who decide to do a lift later on you'll need a 34mm impact socket and a pitman arm puller.
here is the pitman arm installed.
can you tell whats missing?
thats all i have done for now, im hopefully getting the rest of the parts after school today and i MIGHT be able to finish the front!!! ill post some pics later tonight.
Old Nov 29, 2006
jrpro130's Avatar
That is awesome! It should look nice after its done
Old Nov 29, 2006
Sad_Savant's Avatar
dang man!!! that looks awesome!!! can't wait to see more buildup pics!
Old Nov 29, 2006
winks's Avatar
Awesome man, I have the 6" skyjacker lift on my Bronco... it seemed to take forever, but I got it done.
Old Nov 29, 2006
looks real good! what are you doing for rear lift....
Old Nov 29, 2006
blackbetty's Avatar
Thanks Guys! yea i will post some new pics today, i dont think i will be adding anything else today cuz it just started raining a bit....#$%$! so instead im gonna make use of the garage and paint the sway bar red, u-brackets black, and the beam brackets red.
im getting new leaf springs for the rear, add-a-leafs dont really appeal to me and adding blocks is "not right" plus my leafs are starting to really level out.
Old Nov 29, 2006
cool! i am going to get some new leaf packs after christmas i think....
Old Nov 29, 2006
blackbetty's Avatar
yea man! i cant wait till everything is done, tires rims lift gears, cuz then ill be the only one in my school with a kickass lifted truck. like 1/4 of the school drives friggin imports.
these are the rims im getting 16x8, theyre the 1378 series from eagle alloy, theyre 150 a piece.
and here are the tires, 35x12.5 mickey thompson baja claws
Old Nov 29, 2006
i would get BFG Mud-Terrains if i were you.....you wont get any treadlife out of those tires.......
Old Nov 29, 2006
blackbetty's Avatar
Really?? i heard that they last alright, im gonna get the radials does that make a difference?
Old Nov 29, 2006
radials do, but the BFG's last alot longer and have better traction.....
Old Nov 29, 2006
blackbetty's Avatar
Really???
Old Nov 29, 2006
i love my BFG's.......they are prolly even a little cheaper than those....
Old Nov 29, 2006
blackbetty's Avatar
how much did they run you a piece?
Old Nov 29, 2006
a 15" wheel is $180 a tire......
Old Nov 29, 2006
blackbetty's Avatar
thats U.S though, im actually getting those rims in 16" and a tire for that is $240 CAD the baja claws are 174 in the states
http://www.stylinconcepts.com/parts..../categoryid/25
scroll down and look for the 35x12.5's
i appreciate the input though.
Old Nov 29, 2006
fletch12518's Avatar
man the front on mine was a PITA! lol but good luck with the kit! great job so far
Old Nov 29, 2006
awwww i seee you live in Canada!
Old Nov 29, 2006
blackbetty's Avatar
lol yea eh, i dont know about you but its get dark at five 30ish and then i have to bring out the blinding flood light, plus its winter time almost.
Old Nov 29, 2006
blackbetty's Avatar
lol yea i found that the center hinge was the hardest and trying to put the beam's end in the bracket, other than that it was pretty easy.
Thanks
Old Nov 29, 2006
Thanks
Yup. Always start with the hardest first! Save the easiest for last
Old Nov 29, 2006
blackbetty's Avatar
werd...lol
Old Nov 29, 2006
EdGe_wannabe's Avatar
Lookin good man!
Brenton
Old Nov 29, 2006
blackbetty's Avatar
Originally Posted by EdGe_wannabe
Lookin good man!
Brenton
Thanks.....im heading out in 15min to sand and paint the swar bar and parts, ill post up pics later when its dry..lol
Old Nov 29, 2006
that joker is gunna be lookin good my friend
