people with m5od problems please read!
Old Aug 16, 2007
5speedin2.3's Avatar
well after a few months of my trans being hard to shift and grinding, i fixed it.
me and my dad put a new clutch in my truck and the trans tipped over and leaked out most of the synthetic fluid, so we filled it with cheap trans fluid he had laying around.
well, my trans was fine until it warmed up, then it would be really hard to shift into 2nd and 3rd, and you had to grind gears most of the time, i couldn't down shift it, it sucked, i thought something else major was bad.
it was like it was sticking into gears or the syncros where not working.
but! its fixed!
i went to autozone and got three quarts of "Synchromesh" for $20.
it didn't seem to help at first, but after about a mile down the road the trans is smooth as butter now.
feel free to ask any questions.
Old Aug 16, 2007
greygooseranger's Avatar
Syncromesh? Is that synthetic trans fluid? My trans has been kind of picky lately, I am going to do the clutch and slave soon, maybe I should put this in instead of mobil 1.
Old Aug 16, 2007
i have no idea if its synthetic, nor do i care, im not big on the "oh wow its synthetic" thing.
try it out.
http://www.pennzoil.com/products/gea...cro_fluid.html
Old Aug 16, 2007
Pennzoil® Synchromesh Fluid is a synchromesh transmission fluid designed for certain manual transaxles and manual transmissions used by General Motors or Chrysler. Pennzoil® Synchromesh Fluid is formulated with high quality paraffinic base stocks, a fluidity modifier, multifunctional performance additives, corrosion inhibitors, a foam suppressor and a shear stable viscosity index improver additive. It provides excellent oxidation stability, low temperature performance, excellent synchronizer performance and compatibility with yellow metals, such as bronze, brass and copper components found in manual transaxles and transmissions. This product will satisfactorily lubricate General Motors or Chrysler manual transaxles and transmissions from -40°C to +150°C.
Benefits:
* Exhibits excellent low temperature performance
* Meets GM Specification 9985648 and Chrylser Specification MS-9224
* Suitable for use in GM manual transaxles and transmissions requiring GM Part No. 12345349 or 12345577
* Suitable for use in Chrylser transaxles and transmissions requiring Part No. 4874464
* Excellent synchronizer performance
* Excellent yellow metal compatibility
Old Aug 16, 2007
^^^^ It specificly says several times that it is for GM and Chrysler...
Old Aug 16, 2007
so?
it fixed my problem didn't it?
it has also fixed alot of others on RPS..
Old Aug 16, 2007
^^^ I just don't like the fact that it isn't approved for Ford transmissions. Has anyone on RPS put any kind of miles on there vehicle with it? I drive 2000-2500 miles a month, so I would need to know that there aren't any long term affects. Sounds interesting though, I will have to look into it...
Old Aug 16, 2007
Amsoil isn't approved for anything, idk what the problem would be.
its made for manual transmissions, what could it harm?
it obliviously fixed the problem i had with my trans.
Old Aug 16, 2007
a few people on here have switched to synchromesh also.
Old Aug 16, 2007
Well I am hoping to get my clutch and slave put in soon, so I will put it in before we go up north for the holiday...but its your *** if I get stranded....LMAO. J/K
Old Aug 16, 2007
haha it will be fine man, i honestly can't see what it would harm.
if anything, its better because its yellow metal safe.
go upto autozone or w/e your prefer with about $21 and grab three quarts, its by the gear oil.
Old Aug 16, 2007
oh um, i had to use a suction thingy, its hard as hell to put the fluid in without it.
Old Aug 16, 2007
Ok I will... I usually go to Murray's but if auto zone has it for sure, I will just stop on the way home.
On a side note.... How did you bleed your slave? Every time I ask, I get a different answer, so I figured since you just did it and yours works, why not ask...
Old Aug 16, 2007
im quoting this from one of my dads posts.
"the hydro system on these trucks is a "self bleeding" system
all you need to do is fill the master then open the bleeder screw and let it gravity bleed for a few minutes (do not let the master run dry) then close the bleeder screw and simply pump the pedal 40-50 times. the first couple of pumps you may have to help the pedal back to the top. and thats it."
heres a thing on TRS.
http://www.therangerstation.com/tech...leedclutch.htm
Old Aug 16, 2007
yeah most of the time i goto murrays, the prices seen to be lower, but autozone is walking distance from his work so i just went there.
Old Aug 16, 2007
Ok... Too bad I don't live closer to your Dads shop, I would just have him do it...lol
Old Aug 16, 2007
Steve_O113's Avatar
it never says its "only" for GM and Chrystler, what i got from it is those two require a certain type and only that type
Old Aug 16, 2007
ranger's Avatar
you wont use it because it isnt approved by ford? is penzoil part of gm?
Old Aug 16, 2007
yeah, its basically a better fluid for manual transmissions, it helps the synchros, idk im sure someone that knows more about this kind of stuff will chime in.
Old Aug 16, 2007
^^^ I am going to try it, but I was just concerned that it said GM and Chrysler but not Ford.
Old Aug 16, 2007
redneckbrat's Avatar
does that fact they use paraffin, which is used to make candles, bother anyone? it does me. not trying to start anything, just a thought.
Old Aug 20, 2007
Interceptor944's Avatar
I will be picking up some as well I think...Ranger has only 44,000 on it but not sure when they replaced it last so might as well start new :).
Old Sep 16, 2007
mossyoak03's Avatar
ya that **** don't work
Old Sep 16, 2007
wth are you talking about, ive had it in my truck for a few weeks now and it made my trans feel new again.
Old Sep 16, 2007
haha, all his ****s in caps, dont worry about him haha
i use ATF like it calls for, why is calls for AUTOMATIC transmission fluid will always be a mystery to me, maybe ill switch over to syncromesh next time i flush it, i used to work at Vatozone, always saw it but never heard anything about it
