Question/cel
Old Apr 20, 2008
Brit-ranger's Avatar
Question/cel
My check engine light is on, got the codes and it's the old fav lean bank 1 & 2.
My question is will this hose/pipe elbow with a small split in it cause a vaccum leak(see pictures).
This is the top of the engine with the throttle body cover removed.
The middle pipe on the elbow two small splits.What's the part called?
Old Apr 20, 2008
Yes, that is an elbow in the the PCV system and it is a common leaker on the 4.0 SOHC. Codes are usually P0171 and P0174 or similar.
Old Apr 20, 2008
P0171 and P0174 were the codes,so im guessing you can only get the part from ford.
Thanks Bob.
Old Apr 21, 2008
For anyone needing this part the number is 4L5Z*6758*HA Hose/Vent $35
PharmRanger4x4
Jul 13, 2005 05:48 PM
olsonk_89
Jun 8, 2005 11:15 PM
NHBubba_Revisited
42
May 4, 2005 12:19 PM
PickupMan92
Mar 30, 2005 01:20 PM
3LiterBeater
23
Oct 14, 2004 09:20 AM
